Getting a PGA2310 to be silent
Old 16th October 2012, 09:10 PM   #41
maxw is offline maxw  United Kingdom
maxw's Avatar
OK I tried the 120R in series with the output and 10K across the input and it didn't change the noise floor. I don't have any suitable capacitors to use on the input, I only have electrolytic.
Perhaps my layout? Or the relay mounted so close to the PGA?
Old 16th October 2012, 09:33 PM   #42
BenY is online now BenY
I didn`t folow tis thread from the start... But did you try another power amp with your speakers??
Try an Analog one for a change???
Old 16th October 2012, 09:35 PM   #43
rsavas is offline rsavas  Canada
That sucks, wish I could help, noise is always a hard one to figure out and solve.
To review, you have grounded the PGA input and hooked it through a headphone amp and it is quiet. So where is the noise coming from? the $1000?
I have this part breadboarded = wire wrap, on two different assemblies, so that I could write/test my code for it. I have already tried PGA2310 and PGA2311, to verify my code. I have to check I might even have a PGA2320, which is the upgrade to the PGA2310. One proto is running off a +/-5V supply, the -5V is generated from a TC7660 = the worst case supply. I will try and test it out to see how quiet it is, in this worst case situation. The other proto I can use an external PS, LM317/LM337 based. Give me a couple of days and I will report back with my findings. May not help you with your situation but it will be some more information for you to use.
Take care
Rick
Old 16th October 2012, 09:41 PM   #44
maxw's Avatar
Unfortunately I don't have another one on hand right now!
Well the headphones are connected directly to the PGA but yeah that is the gist of it!
I would be grateful
Old 16th October 2012, 09:46 PM   #45
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
What happens if the input to the PGA is shorted to ground? Still noisy?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 16th October 2012, 09:51 PM   #46
Brett is offline Brett
Brett's Avatar
Use another µcontroller pin to drive a relay to stop power up/down pops.
Old 16th October 2012, 09:59 PM   #47
5th element is offline 5th element  United Kingdom
5th element's Avatar
Do you have any other amplifier, like an integrated or so?
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 18th October 2012, 07:56 PM   #48
maxw's Avatar
Yeah.
No, if I had I would have tried it first
I'll pick up a new amp soon and retest. Perhaps a Gainclone or similar. Thanks for the responses everyone!
Old 24th November 2012, 09:00 AM   #49
atupi is offline atupi  Romania
I have built one PGA based preamp from zero (etched my own boards) and is dead quiet until 0 db. When it start to have some gain is has a weak noise.
I've put some pictures here: http://www.diyaudio.com/forums/analo...ctions-76.html
I have separated power supply including separated tranny's for digital and analog part.
Old 26th November 2012, 07:08 PM   #50
maxw's Avatar
I have since retested with a gainclone amp which is also noisy. I think I'm going to try a DAC with a volume control like a Matrix mini-i or Yulong D100.
Getting a PGA2310 to be silentHide this!Advertise here!
silent amp jaudio Chip Amps 1 24th January 2005 05:07 PM
silent headphone electro samurai Headphone Systems 0 3rd June 2004 05:07 PM
Silent Fans jteef Parts 8 19th March 2002 07:50 AM
