Go Back   Home > Forums > Source & Line > Analog Line Level
Old 9th October 2012, 10:46 PM   #21
BigE is offline BigE  Canada
Thanks for the drawing ahaja!
A pic of the boards is in post 19 here.
The Phono Stage
The dual hole marked SG is signal ground on the phono board. This is connected to power supply common between C4 and C5. This is also where the TT ground is connected.
Here, signal ground SG = power PG = TT gnd.
The input is directly above it. Cap C1 is connected *behind* signal input. I am going to connect the RC network between the two holes marked SG and IN.
Old 10th October 2012, 12:10 AM   #22
ahaja is offline ahaja  Poland
You can try solder RC combo on the rca socket.
Dual mono preamp
Turntable
Old 10th October 2012, 12:20 AM   #23
ok.
I only have a mica 470pf. Hopefully that will solve the problem, and I can get some good ones later...
Old 10th October 2012, 01:22 AM   #24
RC network in place.
No significant change with the OPA627 - I did not break it....
Need parts for bypassing the LME49990 at the adaptor level. This is the next step.
Will keep you posted.
Old 10th October 2012, 04:51 AM   #25
qusp is online now qusp  Australia
is choosing a less facetious title...
qusp's Avatar
yeah well in the headphone amps and low power poweramp designs by opc he gets essentially perfect results (-160db with all spurs under -148db) heres comprehensive measures of the headphone amps (only the SE-SE and BAL-SE are using the lme as front end) no rail to rail bypasses, just main slightly 'remote' 330uf polymer caps, 10uf X7R ceramics on the buffers rails and 1uf on the 49990 rails, both directly on or very close to the pins and shunting to the solid ground plane. with good PCB layout and careful wire/connection routing, there is no need for so much parallel capacitance.
Old 10th October 2012, 12:20 PM   #26
What can you do without a ground plane?
Old 10th October 2012, 12:25 PM   #27
sachu888's Avatar
If you see closely my DIY CNC phonostage,you will find 4 (yello colour) .1uf 50V multilayer Ceramic caps very close to Opamp socket pins.They are there to stop oscillation from Opamps.
Sachin
Old 10th October 2012, 02:50 PM   #28
qusp's Avatar
use a solid piece of copper foil and make it your ground plane, or you can buy soic adapters that already have bypass cap positions
Old 10th October 2012, 08:58 PM   #29
Could you tell me please, where can I find those soic adapters?
The goal here is to replace a socketted opa627 with the LME49990.
I got my LME49990s pre-mounted from proto-advantage.com. They are Canadian, and ordered the opamps for me, thus extreme shipping costs.
Old 11th October 2012, 02:59 AM   #30
sachu888's Avatar
Cheapest I have found here 2* Dual SOIC to DIP-8 Convert PCB Adapter SMD OPA627 | eBay
BTW PM me if you want to try CNC MM Phonostage ,(see my signature)This is the best Phonostage I have ever heard and can be built under $50.
Sachin
LM4702 reference design note 1490 - ideal 1st amplifier? Spasticteapot Solid State 8 20th February 2013 09:47 PM
LME49990 Audio Op-Amp - better than AD797? tiefbassuebertr Solid State 36 9th January 2013 06:48 AM
On a design note jjl Full Range 5 30th January 2012 07:22 PM
FS: Dual LME49990 on DIP adapter theAnonymous1 Swap Meet 0 7th September 2011 06:28 PM
FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" Joseph0 Swap Meet 1 24th May 2006 05:17 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
