diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Analog Line Level (http://www.diyaudio.com/forums/analog-line-level/)
-   -   Cg in THAT 1512 (http://www.diyaudio.com/forums/analog-line-level/220856-cg-1512-a.html)
card9inal 2nd October 2012 05:05 PM
Cg in THAT 1512
Hey everyone, I'm putting a pre-amp in a project and I was given some THAT 1512 pre-amp chips. It's the first pre-amp I'm building, so I'm still pretty green with this type of stuff, pretty much an electronics noob in general too.
Reading the datasheet, I'm going to build the circuit in Figure 4.
http://www.thatcorp.com/datashts/THA..._Datasheet.pdf
On page 5, it states that Cg must be large enough to at smaller Rg values. My guess is that I'll probably be using <100 ohms at Rg. It recommends 6,800uF, but that doesn't seem right... Seems like that's waaaay too high of a value.
Does anyone have any experience or any advice on how to properly build that circuit?
Thanks!
SY 2nd October 2012 05:53 PM
You want the time constant for the RC to be at least a decade lower than the lowest frequency of interest. Let's say the resistor is 100 ohms and you want to go down to 20 Hz. Then a decade below is 2 Hz, so using C = 1/2pifR, we get about 800 uF. If the resistor is smaller, the cap will be proportionately bigger.
stellavox 3rd October 2012 12:37 PM
THAT is correct. If you want 60dB pf gain, Rg is 10 ohms. I use the 6800uF.
They have an application note that explains things more fully.
Charles
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
