Ultrabass, psychoacoutstic low bass for little speakers - Page 7 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 19th October 2012, 09:05 AM   #61
I have enclosed the exponential circuit that "worked" best in the simulations. There is room however for better dimensioning.
The working principle is that the exponential relationship of base current and base voltage of Q13 is used to caues an output voltage from E17. The voltage sources are set to a gain of 80 dB and are therefore quite good approximations of OP-AMPs. R68 is there to bias the circuit such that the base voltage doesn't get negative during the lowest point of the negative going halve-waves of the input signal.
Q12 and E16 are there to set the bias for Q13 and for thermal compensation. This part of the circuit might have a tendency for oscilations in real-life. This could be solved with a cap from the output of E16 to its inverting input (i.e. the classic dominant-pole compensation).
Any small-power NPN should work. Just take care that they are of the same type and that they are thermally coupled (and no don't directly solder metal-can types together as most of them have their collector connected to the can).
I think it sholdn't be a bog problem to design the filter and summing stages. At least not the circuit itself. Finding the best filter cutoff frequencies might be a matter of trial and error and of course personal taste.
In a few weeks I will have some more time and probably try it on a DSP. I play ERB and will probably make some sound samples if the effect is worth it.
Charles
Old 23rd October 2012, 09:22 AM   #62
danielwritesbac's Avatar
Charles? Curiosity got me. What is an ERB?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 23rd October 2012, 10:22 AM   #63
the component values depend upon what device you use and what Voltage you run it at.
I haven't had chance to build a breadboard version yet but mine will be run from a split supply and used mains powered, so battery life is not an issue, the 074 is also a device that draws more quiescent current than you would desire for battery operation, but I have a supply on hand and use them in test instrumentation..
rcw
Old 23rd October 2012, 12:24 PM   #64
This is the one I will be committing to breadboard..
The filter and the mixed in level are adjustable in this to allow adjustment for the best subjective effect.
rcw
. Edit:- The shunt capacitor should have a value of 4n7, not the on on the diagram.
Old 27th October 2012, 06:36 AM   #65
ERB = extended range bass
Charles
Old 27th October 2012, 01:35 PM   #66
Charles
Oh yeah, that's a good test. Big extended range bass meets. . . little speaker.
Old 12th August 2013, 02:58 PM   #67
Housekeeping. At post 1, the link to HeadWize bass enhancement quit working after they had a server problem and lost about a quarter of their projects. So, here it is secured as a PDF.
File Type: pdf Jan Meier - Psychoacoustic Bass Enhancer.pdf (456.9 KB, 257 views)
Old 12th August 2013, 03:31 PM   #68
dipolar is offline dipolar  India
dipolar's Avatar
What is an analog multiplier ?
I know logarithmic amplifiers only
Old 14th August 2013, 04:06 AM   #69
keantoken's Avatar
An analog multiplier is basically an AGC circuit. It is an amplifier who's gain (multiplier) is set by a control voltage. An AM modulator is also one. It does this using analog components rather than digital logic.
Logarithmic amplifiers can be used to construct an analog multiplier by putting an anti-log amp after a log amp and then adjusting the offset of the log amp.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 31st January 2016, 10:04 PM   #70
Daniel,
Did you ever find a good final circuit design that worked well for this application? If so, can you share the schematic?
Thanks,
Jim
Car subwoofer sounds muddy but hits low bass well (sluggish bass) dannyjmf Subwoofers 11 24th August 2012 07:01 AM
How low in bass do dipole surround speakers go? goldyrathore Multi-Way 3 3rd November 2010 05:38 PM
low punchy bass simza03 Subwoofers 3 30th August 2009 11:03 AM
notch in the low bass Williams Audio Multi-Way 0 29th September 2006 07:45 AM
Help for low/bass freq. arma61 Multi-Way 13 27th February 2006 06:42 PM
Copyright 1999-2017 diyAudio
