Ultrabass, psychoacoutstic low bass for little speakers
Old 5th October 2012, 03:40 PM   #41
phase_accurate is offline phase_accurate
Whether such things would actually decrease distortion would have to be tested in practice. Keep in mind that all the networks used for synthesizing bass are highly nonlinear functions.
While we are at it, the classic compensated two-transistor antilog (or exponential) generator is indeed much easier to get right than the 1 transistor one I was playing around with (to be clear I did this all with a simulator so far).
In the enclosed diagram you can see the (augmented) varying input signal from 0.1 to 1 Volts and the respective output signal of the circuit.
Charles
Last edited by phase_accurate; 5th October 2012 at 03:49 PM. Reason: removed some (embarassing) typos, might probably not have found all of them
Old 5th October 2012, 03:47 PM   #42
After removal of the DC component (one would have to highpass filter anyway) the spectrum is looking the following way for a steady input signal of 1 V (eff).
Charles
Old 5th October 2012, 10:56 PM   #43
rcw666 is offline rcw666
Some things never change it seems.
I remember radio grams with low frequency drivers having non linear suspensions, everything bellow about 100Hz. came out as second harmonic.
rcw
Old 6th October 2012, 11:40 AM   #44
R.I.P.
One thing to note here is that all you after is low bass roll-off and
enhancement of the fundamentals harmonics, presumably the
more the lower the note with an emphasis on second harmonic
with reducing higher order harmonics.
As mentioned earlier in this thread, probably the best way to
do that at line level is arranging to drive a small transformers
primary into bass saturation at the constant levels before
the volume control. Its easy to arrange a "drive" control
with this arrangement. Also varying some DC current
through the primary as well as the AC will add a lot
more and control the even harmonics at the output.
rgds, sreten.
Old 6th October 2012, 07:12 PM   #45
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
rcw
I already tried boomy box tuning in combination with a capacitor series to the speaker to roll off more fundamental than harmonics. And unloading the amp for signal the speaker can't output is quite helpful for battery run time. Well, the large signal work reduced the x-max problem and the frequency response ended up level, but the effectiveness was insufficient. The only thing the cap did was cut some of the boom and cut most of the treble distortion. What has not changed is that the lowest string is audibly missing from the bass guitar. . .
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 8th October 2012, 06:37 AM   #46
You can of course put a cap in series with a woofer but the result maybe quite different from what you expect. You will have to take the interaction between the capacitor and the driver's impedance into account. Maybe you already did.
The German mag "Hobby HiFi" is using the approach quite often and they once published the design rules they usually apply.
And there was an article by A.N. Thiele in the JAES recently where he showed how to properly dimension series caps. AFAIR he was dealing with closed-box speakers only.
Dependig on how much you want to (or have to) cut off you might be better off by "synthesizing" the series cap by frequency-dependant current feedback. You will loose the impedance transformation effect but you will also relieve the amp from signals that the speaker won't reproduce.
Charles
Old 8th October 2012, 08:14 AM   #47
mattlong8 is offline mattlong8  United States
mattlong8's Avatar
Have you seen Maxxbass? Not really DIY but it's supposedly good.
Maxx - Professional Sound for Consumer Electronics
Old 9th October 2012, 02:29 AM   #48
Before: The lowest pitch string of the bass guitar is absent and the three higher pitch strings play with a boomy distortion with only 3 watts till x-max.
After (4R, 1100u): The lowest pitch string of the bass guitar is still absent but the three higher pitch strings play with a loud clear level response to 10 watts.
This does a useful job, but doesn't really replace the ultrabass circuit.
Old 9th October 2012, 02:53 AM   #49
Originally Posted by mattlong8 View Post
Have you seen Maxxbass? Not really DIY but it's supposedly good. Maxx - Professional Sound for Consumer Electronics
There's lots of those: Digital Bass Reconstruction Processor
No idea if that's:
Harmonic divider (DBX120A)
Harmonic even multiplier (distastefully boomy)
Harmonic odd multiplier (Ultrabass)
Old 9th October 2012, 03:15 AM   #50
Putting, "digital" on something is still just marketing hype, what they are doing is to generate second and third harmonics from the frequency content bellow a particular cut off, and then add that to the direct sound.
It is true that you can add a few more wrinkles with digital processing, but I have never seen any reliable research that indicates this is worthwhile, just manufacturers marketing hype.
The various analogue schemes already mentioned are all you really need for a diy device, the other stuff is convenient for manufacturers because they can integrate it very cheaply, but despite all the hype, I very much doubt if is better.
All of the schemes mentioned are much the same in that they essentially multiply the input with a natural anti log function.
As you can see from phase accurate's data, this results in a linear descending series of even and odd harmonics, a full wave rectifier gives the same thing with the odd harmonics missing, and dc saturating a signal saturated transformer gives much the same sort of thing.
The circuit I am looking at uses a full wave rectifier connected as an integrator, this is basically the circuit I posted with the addition of a capacitor.
rcw
Ultrabass, psychoacoutstic low bass for little speakersHide this!Advertise here!
Car subwoofer sounds muddy but hits low bass well (sluggish bass) dannyjmf Subwoofers 11 24th August 2012 07:01 AM
How low in bass do dipole surround speakers go? goldyrathore Multi-Way 3 3rd November 2010 05:38 PM
low punchy bass simza03 Subwoofers 3 30th August 2009 11:03 AM
notch in the low bass Williams Audio Multi-Way 0 29th September 2006 07:45 AM
Help for low/bass freq. arma61 Multi-Way 13 27th February 2006 06:42 PM
