Go Back   Home > Forums > Source & Line > Analog Line Level
Old 25th September 2012, 06:09 PM   #11
morinix is online now morinix  United States
Originally Posted by RJM1 View Post
C6 should be a non-polarized capacitor, but fitting one in there might be a problem.
C1 and C2 should be non polar too if possible.
Robert
Lounge Audio
Old 26th September 2012, 08:32 AM   #12
ds23man is online now ds23man  Netherlands
There is one important thing to consider if you are going to swap opamps: power consumption! If you swap all your opamps for a type with a much higher consumption, the power supply may give in!
Old 26th September 2012, 09:01 AM   #13
Good point!
Again I find myself agreeing with Jim Williams' advice: Get a larger Soundcraft psu than the one that came with the console regardless of upgrades.
They come up on ebay regularly and sometimes quite cheap.
Old 26th September 2012, 06:08 PM   #14
I have found non-polarized capacitors at RS at the right values, in sized that could be mounted on the board.
At first I will try to do the upgrades on a few channels, so I can compare them to the stock channel strips.
I am well aware about the problems of changing opamps and the power consumption. I am fully capable of making a more powerful powersupply, at least for the +/- 17 Volt audio supply myself, out of components and materials from my work. Many of these standard components (Low-ESR caps, resistors and opamps) I can either get from my work, or order relatively easy. So cost is less of an issue.
Would there be any point in maybe having a couple of transformer coupled channels? Could that have any sonical benefits?
I also found this post at Gearslutz from Jim Williams about the Soundcraft 1600 (which is basically the same as 800B but with a patch bay):
1600's and 2400's used a standard instrumentation amp design for the mic preamps. It's a pair of noisy 2N4403 switching transistors in front of a 072 opamp.
Modern Japanese transistors will lower the noise, but THD is high with this design at higher gains. It's the same design as used in the TS-24, early 600's and others of that era.
They can be rewired into trans-amps by cutting the opamp feedback loop and tying that feedback resistor to the inverting transistor emmiter. That will lower preamp noise below that of a mic and will lower THD levels considerably. You can get -129.6 EIN with that preamp if reworked.
Jim Williams
Audio Upgrades
And thank you for all your great advice. I am very happy about this desk, and since it is entirely built upon standard components, it will serve me well for many years. I fortunately have a couple of extra channel strips and a group strip lying around.
Old 26th September 2012, 06:37 PM   #15
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Off the top of my head, that preamp looks very much like the 400B I used for quite some years. Nevertheless, I don't think you will gain much in terms of noise by changing the opamps, as it is the two input transistors that sets the noise level. 5532s should be OK in terms of power consumption. I'm not really sure you'd get much lower noise by changing the transistors either, as 2n4403 is concidered being quite good in that respect, and getting any real improvement with other transistors may need a total redesign. Maybe shopping for some used external mic preamps is a better choice.
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 26th September 2012, 07:02 PM   #16
True, reducing noise for the micpre amp will be nearly impossible. But lower distortion and better bass - generally a more open sound can be obtained. Upgrade the power supply, then opamps and caps AND ADD A CURRENT SOURCE TO BIAS THE OPAMP FURTHER INTO CLASS A OPERATION. At least do this to the opamp associated with the mic pre circuit. A lm334 set to even ONE MILLIAMP (62ohm set resistor if memory serves me) will help with low level detail linearity. I learned this from Jim Williams.
Robert
Lounge Audio
Old 27th September 2012, 12:24 PM   #17
Glad you still found a suitable Jim Williams post at gearslutz since he has been deleting a lot of his posts there as I previously mentioned.
I wasn't sure if its cool to mention other fora by name here, some moderators at some fora can get quite touchy about that kind of thing.
-129.6 EIN is not to be sniffed at if you can get that or close to it.
Output transformers should give you a different flavour sound which is/can be a good thing. Output transformers can have more influence on the sound than valves do. In my experience solid state mics with output transformers sound more like vintage valve mics than modern transformerless valve mics.
Enjoy your console and the fiddling with it.
May all your recordings be hits!
Old 27th September 2012, 06:02 PM   #18
And something very important: The SOUND of a console is mostly determined by its EQ section.
Old 27th September 2012, 08:01 PM   #19
Then please explain the existence of analogue summing mixers which mostly do not have an eq section yet sound different from each other or digital summing.
Lots of people buy analogue consoles for their sound yet never use the eq section.
Old 27th September 2012, 08:16 PM   #20
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
It's true, put a Midas XL-88 next to a Rane MLM mixer and there is no EQ, but a huge difference in sound. (They measure differently too!)
How to make mic input transformer 150:50KCT for mic tube preamp??? delipasha Tubes / Valves 9 3rd February 2012 05:54 AM
Preamp improvements/suggestions dwalker0044 Analog Line Level 13 9th June 2011 06:51 PM
B1 passive + Pearl 2 phono preamp + DCPS improvements? intrator Pass Labs 0 17th December 2010 07:46 PM
'Tube' preamp bad for measurement mic? also Apex mic question morbo Multi-Way 10 23rd March 2005 10:19 AM
What mic preamp for Behringer testing mic The Paulinator Multi-Way 1 6th April 2003 07:02 PM
Copyright ©1999-2013 diyAudio
