Design questions for opamp-based preamp
Old 21st September 2012, 05:52 AM   #1
Tolu is offline Tolu  Germany
Tolu's Avatar
Default Design questions for opamp-based preamp
Hallo,
I'm planning a new preamp.
Two questions arose:
One stage (source-pot-opamp)
or
two stages (source-opamp-pot-opamp)
dual or mono opamps
and when using dual version:
L/R in one opamp or 1./2.stage
What sounds best?
Thomas
P.S.: planned opamp: LME49720HA
Old 21st September 2012, 06:21 AM   #2
sofaspud is offline sofaspud  United States
sofaspud's Avatar
It's all somewhat dependent on what you want and need. One stage should be fine for the vast majority of uses. Mono op amps are preferred; if you use a dual, use 1 for each channel. Your planned op amp is a dual, and it would be okay to use it for L/R.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 21st September 2012, 09:24 AM   #3
Tolu's Avatar
I am a little bit confused. You wrote take one dual opamp per channel and in the next sentence take one dual for both channels.
Old 21st September 2012, 09:35 AM   #4
PMA is offline PMA  Europe
PMA's Avatar
When are you planning to start production?
Old 21st September 2012, 09:58 AM   #5
Tolu's Avatar
I preordered at Foxconn capacities for about 100'000 pcs per month (at the expense of the iPhone 5 production).
Fortunately I made my millions in another business so I can bear too high stock buildings.
Old 21st September 2012, 10:24 AM   #6
sofaspud's Avatar
Sorry. Here's what I meant...
Ideally (and measurably also) you'd want to keep the L & R signal paths completely separate. As a practical matter, that may not be the wisest choice. Especially in light of the smaller/faster progress of electronics. Most audio op amps probably have a crosstalk spec, and it's probably low enough that it isn't worth fretting over.
So the chip you mentioned, the LME49720HA, is (if I'm not mistaken) a dual op amp. The LME49710HA being the single. Unless you prefer the bigger, more complex circuit using single op amp chips, the LME49720HA dual chip will do the job.
Design questions for opamp-based preampHide this!Advertise here!
Basic opamp based preamp Stormrider Chip Amps 77 28th May 2013 02:24 AM
can I use this transformer to power the opamp based preamp? zome Parts 3 16th June 2009 11:27 PM
Considerations about opamp based preamp Tolu Solid State 10 12th September 2008 01:10 PM
Opamp based MOSFET amplifier design ronybc Solid State 33 28th July 2004 05:48 AM
Opamp based preamp, for a gainclone Bricolo Solid State 5 9th March 2003 05:36 PM
