Go Back   Home > Forums > Source & Line > Analog Line Level
Old 12th September 2012, 08:18 PM   #1
Default Inverting rail to rail unity buffer
Hey!
I am trying to make a MCU controlled version of something similar to this Lightspeed Attenuator a new passive preamp
I have a DAC hooked up that outputs approx. 0 to +5V and is controlled by an MCU. I am currently using a MCP6002 rail to rail op amp as a non-inverting buffer for the DAC to the first LDR. This seems to work ok but I need an inverting rail to rail buffer that goes from +5V to 0 for the second LDR. I have some difficulties with getting the inverting circuit to have a similar taper to the non-inverting with the MCP6002. Anybody having good suggestions for a circuit?
Hope someone can help!
Old 13th September 2012, 02:50 PM   #2
Itsmee is offline Itsmee  England
Itsmee's Avatar
The easiest way to achieve what you wish is to connect a unity gain inverting opamp input to the output of the non inverting opamp.
For unity gain, make Rf equal Rin.
Old 14th September 2012, 07:00 AM   #3
Have tried. It doesn't follow the non-inverting buffers taper at all. Actually, I just came to think of that I might be able to let one of the LDR's sink then I might not need the inverting buffer (I like the idea with driving it differential though (two wires with constant 5V measured from the outside)).
Old 15th September 2012, 02:03 PM   #4
It may be that you need to subtract your DAC's ouptut impedance from the value of Rin for the inverting buffer circuit. For example, if Rf = 10k, and your DAC's Zout = 1k, then the value of Rin should be 9k.
Ken
Old 16th September 2012, 08:49 AM   #5
Thanks Ken. Actually I think I can see the problem now in what I am trying to do;
I want to run differentiable 0-5V. I am using a rail to rail op amp with 0-5V supply. I goes fine with the non-inverting coupling but the other has an amplification of -1 if Rf=Rin which mean that 5V in makes -5V out (?). But the lowest voltage I got is 0V. The application has to be able to run from a 9V battery as well+protection diode so I have like 8.3V max. all in all. So +-5V for supply on the op amp is not possible. Hmm..any good ideas?
Old 16th September 2012, 10:58 AM   #6
I think I found a solution. As mentioned earlier I'm sinking one of the LDRs and sourcing the other (using two non-inverting buffers). I have to test the circuit a little more en details but it seem to behave.
Old 16th September 2012, 02:01 PM   #7
DUG is offline DUG  Canada
Itsme's circuit need to have the + input at +2.5V
Then it will work for your 0-5 into 5-0
Doug We are all learning...we can all help
Old 19th September 2012, 07:29 AM   #8
Thanks Dug! That was the ticket Works like a charm..
Old 22nd September 2012, 10:53 AM   #9
I am have the same problem and wondering how to get unity gain with that calculation?
how do you find dac output impedance if not quoted in datasheet?
datasheet only gives output load resistance min 3 kohm (tda1549)
thanks
Glen
Old 22nd September 2012, 11:10 AM   #10
Glen: I actually have unity gain (ennough) without considering the DAC output impedance, so I haven't really paid attention to that. I can't see it in the datasheet either.
Wanted: Op-amp with single supply, 32V or more, and rail-rail capability akis Power Supplies 3 13th November 2010 01:53 PM
comining rail to rail and rail to ground decoupling? jazz Power Supplies 2 30th March 2010 01:13 AM
Suggested AWG for 6.3V tube heaters rail and 250V B+ rail eranrund Parts 0 3rd November 2008 07:30 PM
Filter Cap Directly from Rail to Rail, excluding Center Tap Workhorse Power Supplies 8 29th August 2007 12:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
