Replacement cap for Wima MKP10 0,047UF
Old 10th September 2012, 10:14 AM   #1
MiL is offline MiL  Sweden
Default Replacement cap for Wima MKP10 0,047UF
Currently modifying my Copland 305 mark 1 and amongst many component changes looking for a higher quality cap to replace a Wima MKP 10 0,047 uF in the phono section. Other signal caps will be replaced with Mundorf Supreme/Supreme SIO.
There is not much space so bulky caps will not fit however slightly bigger than the Wima will be fine. Hole-hole distance 15 mm.
All suggestions are appreciated/Mike
Old 10th September 2012, 10:18 AM   #2
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Replacement cap for Wima MKP10 0,047UF
polystyrene if you can find any in that value.
Paradise Pre-reg PSU PCBs
Old 10th September 2012, 10:29 AM   #3
Hi and thanks for the suggestion!
I was always of the impression that polypropylene was the no.1 choice. I will look for appropriate polystyrene's.
/Mike
Old 10th September 2012, 11:38 AM   #4
Default for the phono section.
What is the tolerance that this cap needs?
For the RIAA, 1% or 2% are often specified.
regards Andrew T.
Old 10th September 2012, 12:07 PM   #5
I don't really know but the tolerance is no better than 5% for the Wima.
Anyway I have a hard time finding anything 'better' than the Wima, that will physically fit and not cost like a Mundorf Supreme SGIO.
Best/Mike
Old 10th September 2012, 12:09 PM   #6
I have to add that the Wima cap is also specified for AC/DC: 250/400V.
/M
Old 10th September 2012, 12:11 PM   #7
5% tolerance, but did the manufacturer select the caps to a different matching tolerance?
Did they adjust the resistor value/s to match the extremes of a 5% cap tolerance.
Do you know anything about tolerances and computer assisted selection of variable component values?
I don't know much, but I know when alarm bells start to ring.
But just maybe that 47nF is outside the RIAA and has no effect (or little effect) on frequency response.
regards Andrew T.
Old 10th September 2012, 12:21 PM   #8
Hi Andrew,
Sorry to say I do not have that information! I am also not that skilled in amplifier constructions. My approach is to put a better quality cap hence it is in the signal chain and all other caps in the signal chain are Mundorf Supreme/SIO. Though this particular Wima cap does not leave much physical room for the types of Mundorfs et al.
/Mike
Old 10th September 2012, 03:24 PM   #9
To make an informed decision on whether the MKP value is important, you must identify what the cap does.
You should not guess and hope.
regards Andrew T.
Replacement cap for Wima MKP10 0,047UFHide this!Advertise here!
WIMA CAPS for Sale .1uf/1600VDC and .047uf/275VAC udailey Swap Meet 2 11th February 2011 08:46 PM
FS: Wima mkp10 2.2uf 400v dc capacitors 1.99$ each! umut1001 Vendor's Bazaar 8 8th November 2010 11:24 AM
WIMA MKP10 2.2uF Caps For Sale: $19 for 8, Free Shipping USA only Andersonix Swap Meet 9 16th September 2010 09:15 AM
Where Can I get Wima MKP10 4.7 uf in the US? KP11520 Parts 11 9th November 2007 02:26 PM
Wima MKP10 FKP10 Polarized? milanobardo Parts 2 26th January 2006 05:53 PM
Copyright ©1999-2017 diyAudio
