Help in choosing a potentiometer as a "Passive preamplifier"
Old 24th June 2013, 08:25 PM   #21
Wayne Parham is offline Wayne Parham  United States
Wayne Parham's Avatar
Originally Posted by AudioLapDance View Post
Ohh, the Analog Devices AD5206 RDAC does up to 6 ch! (AD5204 = 4ch) That would be great for anyone with a 5.1 setup (HT, surround, ... etc) and those with active crossovers (2 and 3 way!)
Are there any opamps onboard or is it just the resistor network?
Sorry, I didn't see your post until just now. I'm sure you probably found the datasheet by now, but if not:
Visit the π Speakers website
High-quality audiophile loudspeakers and kits
Old 22nd April 2014, 06:24 AM   #22
UMarcus is offline UMarcus  Germany
What are the most sound quality solution for a potentiometer as 'Passive PreAmp' ?
Did anyone comapre some solutions ?
There are :
1. Potentiometer like ALPS (motorized)
2. Relay based Attenuator with resistor array
3. IC based volume control
It should be possible to remote control the volume, so i exclude the switch based solution which is near to relay based solution (?)
Thanks, regards
Marcus
Old 22nd April 2014, 07:15 PM   #23
I'm create a thread for this question
http://www.diyaudio.com/forums/analo...-solution.html
Old 14th July 2014, 01:41 AM   #24
rayma is online now rayma  United States
Originally Posted by ExtraCredit1 View Post
OK so I am using a 10k Alps and have the issue where there is no low end until the pot is turned up to almost max. I am using a Iphone as a source. Should I use a 5k? and if so does anyone know of a good quality 5k volume pot?
Thanks!!
Mike
That doesn't really make any sense. But, have you tried a buffer before or after the volume control? That might localize the problem.
Old 3rd February 2015, 04:09 AM   #25
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Is the pot wired to progressively short the source's output? With a finite output coupling cap, that would give you those symptoms.
All good fortune,
Chris
Old 3rd February 2015, 06:05 PM   #26
R.I.P.
No.
The source sees the vol pot resistance in parallel with a variable impedance.
When the vol pot is set to minimum output the parallel impedance is effectively infinite and the source sees only the vol pot resistance.
When the vol pot is set to maximum output the source sees the vol pot resistance in parallel to the input impedance of the receiver after the vol pot.
eg.
a 10k vol pot
a 100k receiver with and RF filter of 47pF and a cable of 300pF and etc...
At minimum output the source sees the 10k.
at maximum output the source sees 10k||100k||47pF||300pF
and the source must be capable of driving this impedance adequately.
regards Andrew T.
Old 6th February 2015, 12:16 PM   #27
DF96 is offline DF96  England
Not if the pot is wired back to front, as is sometimes done by newbies or those who prefer 'innovation' to sound engineering.
Old 7th May 2015, 01:48 PM   #28
cspirou is offline cspirou  United States
This is a good post.
What about when the potentiometer is integrated in a stereo amp? Is there such thing as having a wrong value or using too high of a potentiometer resistance? The problem of a low pass filter forming from cable capacitance seems completely avoided. So why wouldn't I want to use a 50k or 100k potentiometer for volume control?
Old 7th May 2015, 02:06 PM   #29
The following stage may have by design too low an input impedance to use a higher impedance pot.
A 50k pot has at most a 12.5k output resistance, so you'd want at least 5 or 10 times that for the line stage's input impedance.
Also, internal wiring, or the line amp's input capacitance, may require something more like a 10k pot to preserve bandwidth.
Old 2nd June 2015, 07:32 AM   #30
M Gregg is offline M Gregg  England
Its all depends on,
How much series resistance there is with different settings of the volume control..at full volume low series resistance / at low volume higher series resistance..thats not taking into account the drive of a cable if its remote or the lack of a cable if its intergrated..so from the point of an integrated amp the drive required after the control is different to at a remote distance.
miller capacitance and series resistance..is another issue.
Another is the current available for drive is divided at the pot.
So with a higher value pot you get more series resistance at low volumes, however at higher settings the dividing resistance is higher to ground.
(as usual its a trade off) So you are asking for a linear device with varying parameters of real life conditions.
(You are changing the circuit and expecting the same behaviour in all positions). ie even expecting a passive to be plugged into other amps and work the same..
how audible that will be is another issue.
Then there is the loading effect of the value of the pot on the driving stage (input device) and if there is a cable before the pot (connection from device to passive) or if its on the output stage of the source before the cable.
So you want maximum drive for the cable..unless its integrated. Trouble is you have an input cable and / or output cable (with a passive pre).
ie a load on the drive stage with a cable load and a divider driving into an output cable plus input load(amp).
M. Gregg
Help in choosing a potentiometer as a "Passive preamplifier"Hide this!Advertise here!
"...the best preamplifier ever made" says Mr. David Price, Hi-Fi- World tiefbassuebertr Analog Line Level 78 4th January 2018 11:17 PM
KIT - "FlatBT" audiophile grade LINE preamplifier boraomega Swap Meet 10 4th January 2018 03:16 PM
DIY "ribbon controller" slide potentiometer-please help with blueprints! VvvvvV Instruments and Amps 4 21st January 2007 08:51 AM
WTB: stereo potentiometer ALPS "black beauty" or... kasra Swap Meet 8 10th October 2002 05:54 PM
Suggestions on a preamplifier project with a "A/V processor loop" option Spyhunter Solid State 6 8th November 2001 09:31 AM
