Help in choosing a potentiometer as a "Passive preamplifier"
Old 16th September 2012, 09:13 PM   #11
R.I.P.
The best ~ 10K pot is a ~ 100K linear with an ~ 15K for pseudologarithmic.
rgds, sreten.
Old 13th November 2012, 09:36 PM   #12
Esperado is offline Esperado  France
Banned
Potentiometers are not the most transparent device to tune the volume. Mobile contact+carbon resistance are far to be ideal. (noise, grainy sound)
Better to go for metallic resistance arrays, mechanically (rotators) or electronically switched. You can even set that way a constant source impedance for your amp, where it behave the best. (low pass filter in it, square waves overshoots etc.)
Old 14th November 2012, 10:39 AM   #13
DF96 is offline DF96  England
Much of the music we hear will have already gone through a number of carbon pots and carbon film resistors. The contact resistance is not too much of a problem provided the next stage has a high input impedance, and no DC current draw. Switches can introduce clicks unless DC is kept well away.
Some people prefer switched attentuators and they may in theory be best, but many have also been disappointed to find that they can't have them without also introducing extra coupling capacitors and ground resistors. As in all engineering, you have to choose your compromises carefully.
Old 2nd December 2012, 09:58 AM   #14
MLStrand56 is offline MLStrand56
Originally Posted by deChrLam View Post
I think I should just use a 10K logarithmic potentiometer to get a nice pure sound
Can you please explain why you chose a logrithmic pot, over a linear pot? A linear pot gives you more precise control of the output level.
Japanese components typically use logrithmic pots, because they give the false sense of a much bigger amplifier. American/European components typically use linear pots, because they are more acurate.
MLStrand56
Old 2nd December 2012, 10:58 AM   #15
R.I.P.
A linear pot will give you awful control of volume levels, not precise at all.
The best way is a linear pot with a log law faking resistor.
It will have far better channel matching than a dual log.
example from ESP of a linear pot + log law faking resistor
Channel matching at low levels can be improved further by adding
a resistor that gives a minimum gain, rather that zero, at zero.
rgds, sreten.
Old 2nd December 2012, 11:11 AM   #16
R.I.P.
........................... A linear pot gives you more precise control of the output level.
misquotes and misinformation !
regards Andrew T.
Old 2nd December 2012, 03:31 PM   #17
In a conventional pot (whatever law) the worst piece of resistance is the wiper-track interface. Therefore you want as little current as possible through this resistance, so any resistance variation does as little damage as possible. Adding a law-changing resistor to a linear pot does the very opposite. OK in an emergency if the right pot is not available, but I would avoid it when possible.
Old 2nd December 2012, 08:15 PM   #18
Banned
The sensibility of our ears is logarithmic. A perfect logarithmic pot will gives-you the feel of the same volume increment for each same angle increment, while a linear pot will up most of the power at its beginning.
A pseudo logarythmic pot (they are all pseudo) is make of several superposed carbon slices at various places. It is more prone to generate parasitic noises when you move-it.
I have mitigate comments about you entry. In fact, in professional mixing desks, we use plastic Penny and Gilles linear potentiometers. And more and more records are produced in the Digital domain.
Despite i'm very suspicious about "audiophile" differences, i found carbon resistances to sound a little grainy, comparing to metallic ones.
Too the relative precision between the two channels of a traditional potentiometer is far to be perfect, and can lead to a little change in the balance between the two channels. reason why we used rotators and array of resistance in our amps.
Not to forget you can find very good sounding cheap circuit we can use as remote control resistances array based. As an example: http://cgi.ebay.fr/CS3310-Crystal-Volume-Remote-Control-Preamplifier-Kit-/260706392408.
Did-you agree ?
Old 20th February 2013, 03:05 PM   #19
Wayne Parham is offline Wayne Parham  United States
Wayne Parham's Avatar
I built a remote control using an Analog Devices AD5206 RDAC, and while it was inititially intended to drive an LDR (which would pass the audio signal), I connected one up to pass the audio signal through the resistor in the AD5206.
It is a linear pot, but the firmware that controls it uses a logarithmic function to control the pot, so the taper is truly logarithmic. As an aside, there are no mechanical potentiometers that have a true log taper - all are approximations.
The AD5206 device sounds very, very good to me. No noise, just purity. Don't know if it was a "proud papa" thing or not, but I ended up selling all my preamps and going solely with this type of arrangement instead.
Here's a write-up of my experience with this approach:
Visit the π Speakers website
High-quality audiophile loudspeakers and kits
Old 20th February 2013, 06:09 PM   #20
AudioLapDance is offline AudioLapDance  Canada
Ohh, the Analog Devices AD5206 RDAC does up to 6 ch! (AD5204 = 4ch) That would be great for anyone with a 5.1 setup (HT, surround, ... etc) and those with active crossovers (2 and 3 way!)
Are there any opamps onboard or is it just the resistor network?
Help in choosing a potentiometer as a "Passive preamplifier"Hide this!Advertise here!
"...the best preamplifier ever made" says Mr. David Price, Hi-Fi- World tiefbassuebertr Analog Line Level 78 4th January 2018 11:17 PM
KIT - "FlatBT" audiophile grade LINE preamplifier boraomega Swap Meet 10 4th January 2018 03:16 PM
DIY "ribbon controller" slide potentiometer-please help with blueprints! VvvvvV Instruments and Amps 4 21st January 2007 08:51 AM
WTB: stereo potentiometer ALPS "black beauty" or... kasra Swap Meet 8 10th October 2002 05:54 PM
Suggestions on a preamplifier project with a "A/V processor loop" option Spyhunter Solid State 6 8th November 2001 09:31 AM
