Help in choosing a potentiometer as a "Passive preamplifier"
Old 29th August 2017, 01:40 PM   #91
Mixi is online now Mixi  Austria
so scottjoplin says that it will be fine and andrewt says that the current pre amp configuration together with a 10k pot will lead to problems with the bass. did i get that about right?
seems there's never just one correct answer to a question like that
btw: i talked to the guy who designed my phono stage and he said the output impendancenis 10 Ohms. He suggested using a 100k pot or a buffer amp.
i'm a bit confused
Old 29th August 2017, 01:52 PM   #92
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
The lower the output impedance the greater the load it can drive, so that doesn't make sense
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 29th August 2017, 02:00 PM   #93
DF96 is offline DF96  England
1uF driving 10k gives an LF rolloff at 16Hz. You may or may not find that acceptable; this partly a matter of taste, and partly a matter of which speakers you have and where they roll off. If the 1uF is an electrolytic then you really need 10uF instead, so the cap has very little signal voltage across it at the bass end; alternatively, use a 100k pot instead.
10 ohms output impedance can easily drive a 10k pot. 10 ohms plus 1uF can only drive 10k if you are happy to have some bass rolloff.
Old 29th August 2017, 05:47 PM   #94
thanks for the explanation!
my speakers are rated 35 - 20.000 Hz, so I guess a rolloff at 16Hz wouldn't really matter, would it?
aren't frequencies below 20 Hz inaudible anyways?
Old 29th August 2017, 06:18 PM   #95
It's a good idea to roll off the low frequency to avoid excessive excursion of speakers, particularly if a turntable is your source. Yes, 20Hz is about the limit of audibility
Old 1st September 2017, 03:37 PM   #96
thanks for all your advice.
i talked some more to the designer of the phono stage and figured out that a 20k pot would probably be ideal. i'll keep the phono stage as it is and in combination with a 20k pot the rolloff should be at 6 or 7 hz.
i seem to remember that somewhere on this forum i read about the relationship between S/N ratio and pot values. unfortunately i can't find the post or article anymore. can somebody verify my assumption that a lower pot is desirable because the lower resistance will "kill" (for a lack of a better word) less of the signal and thus less amplification is needed after the pot. With less amplification whatever noise appears in the amp will also be less amplified giving a better S/N ratio. Did I get it right so far?
Would that mean that - all other things equal - a lower resistance pot will play louder (because it "kills" less signal) in any given setting than a higher resistance pot?
Old 1st September 2017, 04:02 PM   #97
No. All resistors generate thermal noise, no matter how 'good' they are. The thermal noise voltage is proportional to the square root of the resistance, so higher values generate more noise. The signal attenuation, on the other hand, just depends on resistance ratios (given a suitable pot value) not absolute values.
Old 1st September 2017, 04:32 PM   #98
stocktrader200 is offline stocktrader200  Canada
blue velvet 50k pot will do the trick.
I'm looking at the 10k or 20k one, however I have a preamp before the pot
Less amplification after the pot will reduce noise levels
It won't be any louder but noise levels will be less. Lower resistance will also make it flatter response when driving cables or stages with larger miller input capacitance.
Old 2nd September 2017, 08:43 AM   #99
cool, thanks for the explanation!
Old 2nd September 2017, 09:20 AM   #100
Where to have gain and attenuation is a balancing act. This is worth reading Setting Sound System Level Controls
Help in choosing a potentiometer as a "Passive preamplifier"Hide this!Advertise here!
"...the best preamplifier ever made" says Mr. David Price, Hi-Fi- World tiefbassuebertr Analog Line Level 78 4th January 2018 11:17 PM
KIT - "FlatBT" audiophile grade LINE preamplifier boraomega Swap Meet 10 4th January 2018 03:16 PM
DIY "ribbon controller" slide potentiometer-please help with blueprints! VvvvvV Instruments and Amps 4 21st January 2007 08:51 AM
WTB: stereo potentiometer ALPS "black beauty" or... kasra Swap Meet 8 10th October 2002 05:54 PM
Suggestions on a preamplifier project with a "A/V processor loop" option Spyhunter Solid State 6 8th November 2001 09:31 AM
