| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I'm the kinda guy who designs circuits when I have nothing to do.
So recently I designed an ABX switch box using discrete logic. Here's my Conceptual Schematic: It seems to work fine in my simple Java circuit simulator, but I'm not sure if this will really work. So is there anyone with electronic experience who can give me some feedback? (anything wrong, improvements?) Notes: Relays aren't drawn here because this simulator doesn't have the reed relays I'll be using. The "ABX Switch" has a center-off position. The "Randomize X Switch" is a Push-switch. The "X" random is generated using a square wave and a human controlled "hold" switch. Picture it like a wheel of fortune or slot machine if you will. The "OR" gate in the center that's connected to its own input is used to hold the "X" status, so that the status of "X" will be the same every time until the "Randomize switch" is pushed EDIT: I may switch the NOR gate for an OR gate and Discrete CMOS NOT Gate (Using 2 MOSFETs), because Logic gates comes in packages of 4s. Anyone know a small complementary MOSFET pair I could use? (No surface mount packages) Last edited by b1o2r3i4s5; 3rd September 2012 at 02:12 PM. |
#2 |
From a user point of view, what does he do to change from A to B to X? Reversible? How is the "final answer" and the actual option presentation recorded?
A nice analog ABX box would be a good thing to have!
If there's a sucker born every minute, where do the rest of them come from? |
#3 | |
The states are changes simply by flicking the ABX switch. The actual state of X can be seen via the "Actual status indicator" (refer to schematic), This is normally hidden from the user. |
#4 |
Thanks. If it's hidden, how is the choice recorded? Tough without a microcontroller... Could you add a few gates, let the user guess after he's switched back and forth enough times, and then a red or green LED comes on depending on whether he's right or wrong? The user then has to record his track record, so the controls for a third party aren't tight, but it can be useful as a training tool or individual curiosity (like the ABX function in foobar).
#5 | |
While it's not hard for me to add a few memory registers to record X states (4 maybe), it'll get quite complex construction-wise without PCBs. Since the whole point of this is that µCs are not required, people who don't have access to µC tools probably can't make PCBs either... |
#6 |
#7 | |
Here's an extension of my previous design WITH Data logging! It supports up to 8 testing trials with trial # indication AND the X state in each trial! (Green LED = A, Red = B, yeah... i know you can't see it.). Pressing "Randomize X" again at the 8th trial will reset all recorded data.
#9 |
| 74HC logic or No logic feedingthe Interface Receiver. | Mario_JR | Digital Source | 2 | 10th July 2011 08:18 PM |
| ABX Switching Box for Phono + Line Preamps | thermionic | Solid State | 0 | 11th February 2008 07:39 PM |
| 74AC logic V.S. 74HC logic ? | fastcat95 | Digital Source | 0 | 16th December 2006 03:03 PM |
| My GC STK4231-2 Subwoofer amp, should I switch to discrete? | EWorkshop1708 | Chip Amps | 5 | 27th December 2004 11:14 PM |
| Switch box | scarr3d | Parts | 1 | 26th October 2003 07:57 PM |
