Wiring advice for internal pre amp inputs
hi
I have an AGI 511 pre amp, which has rear RCA connectors that need replacing (they don't make proper connection). They are mounted on a daughter circuit board and I have not been able to find suitable replacements for them. The daughter input circuit board is connected to then main PCB by a flat ribbon cable and computer type connectors.
My plan is to replace the daughter PCB with individual quality RCA sockets (which will fit into the existing chassis just fine) and replace the ribbon cable with individual wiring per socket to the PCB- although this is likely to be fiddly, I think it can be done neatly.
My question is what is the best wire to use for this purpose, and I assume using a twisted pair approach ( two individual wires, one signal one signal ground) twisted around each other is the desirable approach. Do these then need to be shielded?
Any thoughts and advice greatly appreciated
peter
hi
peter
Hi Peter,
I assume that this is a metal-case piece of equipment - if so, you don't need to use shielded cable. Is the mains connection three-prong (grounded) or two-prong (polarized)? Does the small PCB that you are looking to eliminate have any passive or active components on it, or is it only there to hold the RCA jacks? Are the ground wires included in the ribbon cable leading back to the main pcb that you want to replace?
-Charlie
This post was sitting there for quite a while with nobody responding to.
I then decided to make a remark of some sort, one that seemed to be the consensus amongst those who had viewed it, and when I do I am chided for being flippant, why didn't you offer helpful advice in the first place Charlie?
Generally if it was wired with a ribbon cable then twisted pairs will do fine, but it depends upon the grounding arrangements used.
If for instance you find a common ground then the original used a single wire for each output, this is a common scheme.
Outputs that are low in signal or are to go into high impedance inputs are often connected with shielded cable in the Faraday shield mode, in this the shield is connected at only one end.
I hope this has been helpful.
rcw
Hi guys
thanks for the input.....
so it is a metal case (nice and thick and heavy
the ribbon appears to be separate signal and earth for each input, it is built to quite a high quality, and yes there are a few minor components on the PCB which I can attach and then earth appropriately.
the gist of my query is should I use (for example) twisted teflon coated pairs for each input/output or a shielded twisted pair (as I used to use for microphones....like u87's in the days when i made "Records"
If I could find suitable RCA plug replacements I would still need to replace the ribbon cable as it is fraying (the protective coating is coming off)
thanks for reading and replying,
the assistance is appreciated...:)
Peter
Hi guys
Peter
There is a SoCal company called "ApexJr" that sells surplus electronic parts. The owner is Steve, and he is a really nice guy. ApexJr has a permanent thread in the vendor forum here...
Anyway, he sells pretty hefty RCA jacks for $0.99ea, with only a white stripe on them. I have used these and they are good quality. Check out other RCA jacks here:
untitled
Maybe one of those will work for you. In state means fast shipping.
-Charlie
I suggest you avoid shielded co-ax inside the chassis.
Twisted pair is usually good enough for all line level signals. Even the lower levels from old analogue equipment.
mic and phono leads, outside the chassis, do benefit from additional interference attenuation, not line level.
Look at the possibility of choosing where to ground the input signal returns.
You can do this at the PCB or at the RCA sockets.
Both Leach and Self advise that the RCA ground option as a way that may avoid unwanted interference.
I have found that in practice the RCA grounded end offers a more universal solution to most equipment coupling options.
This is achieved by keeping the RCAs fairly close together and linking all the Grounding/Returns with a thick copper wire soldered to each.
Then connect a further copper wire and wrap it around the signal pairs until it reaches the PCB (but not attached), then take that wire to the Main Audio Ground.
NOTE !!!!!
the grounding wire/trace must not create a LOOP that could Receive interference from other Transmitters.
I miss the picture...
Luca
For RCA jacks, if you can afford copper they are a better option than brass, which in turn is better than the super cheap zinc ones... DH Labs has some copper RCAs for $30/pair, decent brass RCAs might be 1/10th that price.
CM-R1 DH LABS RCA Female Jack inside/nut outside mount
For hook up wire I think the silver plated teflon mil spec wire is a good value on ebay or surplus stores, I use 24g solid core for signals. OCC copper is a little bit better but much more expensive.
I agree with hooking up the RCA jacks with a twisted pair.
finished pciture
So, I finally decided to replace like with like, and after quite an adventure found a very charming chap at 3M who steered me to finding the exact replacement connectors, so with new flat cable the pre amp is back to its wonderous self.
I contemplated doing a cap upgrade, but everything measured within spec and it sounds very clean- I have attached a pic from the QA400 and the finished cable replacement
thanks
