Discrete Opamp Open Design - Page 91 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 12th September 2012, 10:56 PM   #901
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by fitzfish View Post
Can we then use /-15 and +/-24 volts as rails for simulation and circuit performance reporting then? If someone has a desire to see low voltage performance perhaps +/-8V would be reasonable?
This is not to limit any rail voltage usage or application but to make compairsons easy between designs for conversation sake. These two nicely cover integrated op amps and the pro audio modules so they are typical usage.
Dave
I'd move to some higher-voltage bipolars for the cascode devices of the gm output stage, and the output buffer, as 4403 is stated as a -40V Vce or Vcb device, thus o.k. with +/- 15 but pushing it for +/- 24. And as I mentioned, cascoding of each BF862 is desirable, although they would be fine at +/- 8.
Old 13th September 2012, 01:05 AM   #902
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default Ready to build Scott's circuit?
I'm ready to build Scotts circuit just to be able to attempt measurement and to listen to such a distortion-less circuit. Are we ready -- seems just output stage isnt finalized but Scotts is more than fine. A better one?
I got to test my simple circuit with Demian Martin's ShibaSoku gear today as a back up measurement to my AP: At 1volt ref output/input shorted - THD = .0005%... 2nd and 3rd in approx equal amounts... other harmonics are -20+ further down from these two. [set at zero dc output]
S/N = -106db with 30KHz cutoff. Imagine cleaner supply lines might help a little as would lower R values in fb and gain. Should be easy (?) to get -110db. But since it wasnt designed for low noise, it isnt too bad for a real built circuit with modest feedback.
Let's build Scotts and see what real world numbers can be obtained vs SIM? I'm collecting parts now. Good ideas and info here - five stars. Who is doing the pcb?
Thx - RNMarsh
Old 13th September 2012, 05:57 AM   #903
PMA is offline PMA  Europe
PMA's Avatar
Hello, these parameters are not so difficult to get. Let me consider them and let me add time response. Blue is input signal, yellow pre output.
Pavel Macura
http://pmacura.cz/audiopage.html
Old 13th September 2012, 06:43 AM   #904
RNMarsh's Avatar
Its something for me to shoot for.... find the circuit that uses the fewest number of transistors that can drive 30 ohms and be dc coupled/stable as well. While thd and s/n is under -100db. Doing it with open loop bandwidth of 20Khz (40KHz preferred). Now if I use different low noise transistors and cascode and the like, then what? But then I have made the circuit a lot more complex and not minimal number of transistors. I met my goal. Would like to see equal or better in all same areas. So far only Scott has risen to the challenge with a great opamp circuit. Lets see your minimalist super circuits. Final data has to be from working circuit not sim. In case of tie (?) the circuit with the fewest transistors wins the gold metal. Thx - RNM
Old 13th September 2012, 12:28 PM   #905
john curl's Avatar
Why not try a variation of this circuit as well, Richard? A few resistor changes, and it should be OK.
"Condemnation without Examination is Prejudice"
Old 13th September 2012, 02:52 PM   #906
Kindhornman's Avatar
John,
And anyone else who wants to answer this question. My question is are any of the proposed circuits that you are showing here actually circuits that you would use in anything but a challenge here to use the least amount or limited amount of discrete transistors. Or is this more like reading Cordell's book on amplifier design and this will technically meet the challenge but in reality to make it a viable product you would have to start adding more devices to make it actually functional for the purpose? I am just curious as to the intent for the design, if it is more than an intellectual challenge.
Steven
Old 13th September 2012, 03:03 PM   #907
scott wurcer's Avatar
Dick, I'm afraid I have to stick with +24dBu output. There are no general purpose amplifiers specified at 1V out only. The JE990 and all available discrete op-amps I can find are specified at 20V p-p out. Professional mixing boards in general use 24V rails and the amplifiers are expected to drive 600 Ohms to near the rails.
There's nothing wrong with a headphone amp that's as loud as you would ever want at 1V, but it is fairly narrow in scope.
Before we build I have one more set of suggestions, that I will get to tonight.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 13th September 2012, 03:05 PM   #908
Lots of junction capacitance at the Vas output, wouldn't a buffer on the MOSFET gates help?
Old 13th September 2012, 03:21 PM   #909
Originally Posted by Kindhornman View Post
John,
Steven
This was not intended as an intellectual exercise in the beginning. After some output stage work I think I can reach (at least) my original goal, a discrete FET input general purpose op-amp with performance as close as possible to the JE990/OPA627/37 when used in the same circuits using almost as few transistors as the JE990 so it fits on a small card. A plus would be an all tiny SMT version.
I would also hope to build and measure a prototype.
Old 13th September 2012, 03:26 PM   #910
Scott,
Thank you for your answer. I was beginning to think this had just become an intellectual pursuit of strange topologies.
Steven
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
