Go Back   Home > Forums > Source & Line > Analog Line Level
Old 23rd August 2012, 12:43 PM   #71
Four of those already dont qualify, over 8 transistors.
No CFB types ???
Old 23rd August 2012, 12:50 PM   #72
dirkwright's Avatar
No CFB types ???
current sources are not counted. But, even so, if you like it and it has more than 8, then since you're a genius you can fix it, right?
I saw some CFB types, but they had way more than 8 transistors. Do you have any examples you'd like to share or are you just going to talk talk talk???
Old 23rd August 2012, 01:40 PM   #73
Anything less complex than a Jensen 990 is a joke, and not worthy of consideration. We are looking for EXCELLENT circuits that we would use in the best audio equipment available today.
Old 23rd August 2012, 01:55 PM   #74
That's the strangest statement .........
Old 23rd August 2012, 01:55 PM   #75
dirkwright's Avatar
I thought you already did that? You're asking US to design something for you?
That would be like Luke Skywalker teaching Yoda how to use The Force.
Old 23rd August 2012, 02:08 PM   #76
Originally Posted by abraxalito View Post
Digikey is listing both the J76 and K213 series as obsolete. So that looks like a dead end then.
Toshiba has some high-gm FETs (even better on paper than Renesas) but they're rather low voltage and have higher thresholds than the laterals. Along with negative Vgs threshold temp coeff.
Hitachi FET To-220ab 200v .5A 30W GSD *SS | HITACHI *SS | Distributed By MCM
Hitachi Hitachi FET To-220ab N-ch 15V .5A 30W GDS *SS | 2SK215 | Hitachi
Hitachi FET To-220ab P-channel 180v 5MA 30W GSD *SS | HITACHI *SS | Distributed By MCM
Hitachi FET To-220ab P-channel 160v 5MA 30W GSD *SS | HITACHI *SS | Distributed By MCM
Old 23rd August 2012, 02:08 PM   #77
scott wurcer's Avatar
Sorry guys EVUL started this so fast I was caught off guard. I hope to put up a couple of ideas later today. I don't think complexity is a goal in itself, performance is. I also don't think a design contest with an 8 transistor limit should be a prime goal.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 23rd August 2012, 02:10 PM   #78
bcarso is online now bcarso  United States
Originally Posted by dirkwright View Post
So, some schematics a copied off a simple search. So much talk, so little action.
Number two (from post 68) is not too bad. Whose is it? It looks like something that really works.
Old 23rd August 2012, 02:16 PM   #79
EUVL is offline EUVL  Europe
Agreed.
Nice to have, not must have (less than 8 active devices).
The same applies to extendability to a fully balanced configuration, a la OPA1632.
Patrick
xen-audio.com
Old 23rd August 2012, 02:18 PM   #80
Eight transistors is RM's idea, although he's already relaxed things a bit by suggesting he might accept cascodes as counting as a single device, and might likewise allow current sources.
I was thinking yesterday of days of yore when transistors were dear, and PNP silicon ones were just becoming available. Some active filter papers were showing a three transistor opamp (they called it a VCVS, voltage-controlled voltage-source, as it was used for that function and typically at very low closed-loop gains). They were quite pleased at the performance attained Sort of the early Western Electric tube stuff in solid-state, and I don't doubt there are a few out there who believe that the simplicity somehow confers some sort of sonic excellence.
Discrete OPAMP audio-gd Vendor's Bazaar 27 20th September 2012 04:02 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2013 diyAudio
