Discrete Opamp Open Design - Page 72 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 5th September 2012, 03:03 AM   #711
Originally Posted by coluke View Post
....THD is now 0.0013% @ 0 dBV into 30 ohm in the 100 Hz - 10 kHz range, low order only (2nd & 3rd).....
coluke, what kind of distortion figures/spectrum do you get OPEN LOOP?
Old 5th September 2012, 03:23 AM   #712
scott wurcer's Avatar
OK, here's one more. Folks asked about subing PNP's for the PFET's, this is one choice using the Rush cascode. The diode connected transistors could be substituted by diodes in most cases. Again use any output stage you like Dick's CF pair or triple-darlington or whatever. The ccomp and the degeneration in the input can be varied for different applications. I think with care this can do anything the OPA627/37 can do. With BF862's we have about $2 in devices.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 5th September 2012, 03:37 AM   #713
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
The jFEts with 100 Ohms in the sources -- is that for CMRR improvment?
Thx - RNM
Old 5th September 2012, 03:44 AM   #714
bcarso is offline bcarso  United States
Me likey
Old 5th September 2012, 04:15 AM   #715
Thx - RNM
That's DC bias, sets the current.
Old 5th September 2012, 07:27 AM   #716
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I like your common mode tricks with diffpairs Scott!
The Devil is not so terrible as his math model is!
Old 5th September 2012, 09:54 AM   #717
tvi is offline tvi  Australia
tvi's Avatar
source resistors - makes matching more critical but THD and Noise is lowest - purist approach
That what this Pioneer patent is said to address
US4356453.html
"Accordingly, an object of this invention is to provide a grounded-source type field-effect transistor circuit in which the source resistance is minimized to minimize the thermal noise in the circuit and to increase the circuit gain."
Adds more devices though.
rgds
james
The small part of ignorance that we arrange and classify we give the name of knowledge.
Ambrose Bierce
Old 5th September 2012, 02:40 PM   #718
US4356453.html
rgds
james
It can be seen in Pioneer A09 amp, excellent amp of late 80s and 90s. Some seem to think the idea is new.
Old 5th September 2012, 03:07 PM   #719
US4356453.html
rgds
james
Looks like they used two current sources to increase the drop in the source resistors, i.e. more offset range with smaller resistors. Smaller resistors = less noise. The current sources are not in the signal path and can be made to not contribute noise (heavy degeneration). This trick also works in output stages to make the Vas current and output bias independently trimmable.
On another point, if you look at the ideal JFET equations you will see that the cancellation of the quadratic term requires both Vp AND Idss to be the same. This would require exact complimentary pairs not just Idss selection.
Old 5th September 2012, 04:15 PM   #720
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
There is another way
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright 1999-2017 diyAudio
