Discrete Opamp Open Design - Page 71 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 4th September 2012, 10:13 PM   #701
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I like augmented emitter followers.
Edit: like'em more than "Cascoded output stages"
The Devil is not so terrible as his math model is!
Old 4th September 2012, 10:35 PM   #702
Originally Posted by bcarso View Post
…I'll get a noise measurement of it soon, but according to Dimitri they manage about 1nV/sqrtHz.
Good enough! Looking forward to confirmation as well.
…Until NXP is persuaded to make a BF862 dual (and the latter was developed for AM radios, so the prospect may be unlikely) they are very attractive.
Your right. Easy to overlook the obvious connection shortcoming with the other apparent virtues of the 2sk2145.
I was thinking vertically in that circuit. Delete the degen resistors and save the space by using two K2145s instead of four with the BF862.
Now you are getting practical! These other aspects are often viewed as an afterthought, some of which that can be brushed aside by invoking a better power supply etc. Considering them at or near the outset is wise.
Absolutely. How well can a simple circuit work as a functioning op amp. Judging each on these secondary effects is just as important as they may overshadow the primary performance metrics if not measured and understood for a particular use or implementation.
Another consideration is to look throughout, especially near the input stage, at how much signal swing changes power dissipation, i.e., thermal distortions, and also how the design responds to more-than-zero source impedance. And --- how does it handle overloads?
For JFET diff pairs in small footprint circuits I have been looking at simple folded cascodes using MMBFJ111 JFETs with Vgs thresholds in the 6 volt range. Any suggestions?
Overlaod recovery, clipping behavior, assymetrical clipping - all good points to consider. So are possible shorted outputs during cable changes... pop then smoke???
Originally Posted by zinsula View Post
Dave, I found your proposal very interesting.
Thank you. Been looking at variations of it for a while and like it for its simplicity. This and several of the other examples posted can be made pretty small.
But now, what circuit are you talking about?
This one from Scott was specifically what I was suggesting parts for.
Generally, are we talking about several circuits, every one heading for another direction?
Several circuits recently. It really has been all over the place since starting.
Just my opinion but I think we should build a number of them then test to see how well things really work. Patrick (EUVL) is working on a version of this Kaneda/Constellation like circuit. I have a layout in progress of my SE circuit. Scott's and others deserve some solder at some point as well.
I hope that others will build more of the proposed circuits. Some of these have little chance of fitting on a dip8 footprint like Patrick’s and mine so the API 2520 footprint could be used instead for ease of comparison...
Dave
Old 4th September 2012, 11:22 PM   #703
coluke is offline coluke  Italy
Got a bunch of J113s from Mouser, did a (not so) quick selection and tested again the design in #451 (with some major changes - no cascoded input fets: I'm a lazy guy ). This, besides reminding me why I really don't like designs requiring selected devices, makes me wonder wonder if the results are worth the time spent (well, not that long - 1 hour or so, but it was pretty boring, and I'm so lazy...): THD is now 0.0013% @ 0 dBV into 30 ohm in the 100 Hz - 10 kHz range, low order only (2nd & 3rd), BW is ample and DC drift just absent or so (output offset changed by less than 1 mV over 2 hours) - same operating conditions I described in my previous post. Quite a remarkable result for a 10 devices design with a far-from-optimum layout (still breadboarded, I mean); but I'm pretty sure I can't hear THD in the 0.005% range, so my somewhat philosophical question is: I'm quite happy to lower further an already pretty low THD figure by selecting devices, but maybe trying to design a circuit which doesn't rely on selection to perform well is a better approach - isn't it? To me, at least: all in all I'm not an audio professional, but an experimental physicist - have to throw in the circuit a bunch of randomly selected fets and see what happens, and if I can manage to hear any difference at all...
Ciao,
L.
Old 5th September 2012, 12:55 AM   #704
expert in tautology
bear's Avatar
Not sure, but I thought I had read somewhere that paralleling input devices reduces noise?
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 5th September 2012, 12:57 AM   #705
bcarso is offline bcarso  United States
diyAudio Member RIP
Dave
Perhaps not DIP8 footprint on a single board, but one can make a layer cake and get a lot more parts down if needed.
Old 5th September 2012, 12:59 AM   #706
diyAudio Member RIP
_-_-bear
It will reduce "series noise" (aka "voltage noise") and increase "parallel noise" (aka "current noise"). With FETs there is very little of the latter at audio frequencies, so it can help IF you can tolerate the increased capacitances.
Old 5th September 2012, 01:19 AM   #707
Absolutely right. I have some layouts like that. Truth be told, a few were fixes once in production (not audio)... Some discrete amps use right angle boards for most of the components with the dip8 footprint simply for the transition to the standard pin locations.
The AP 2520 footprint was an easy (read more space) option without 3D construction so I brought it up. Dip8 interests me most so I foresee some vertical construction in my future.
Old 5th September 2012, 01:38 AM   #708
Ergo the quietude of power mosfets with their many parallel cells.
(mentioned before, but I think a mostly unexplored avenue)
Old 5th September 2012, 01:39 AM   #709
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Originally Posted by coluke View Post
Got a bunch of J113s from Mouser, did a (not so) quick selection and tested again the design in #451 . . . hear any difference at all...
Ciao,
L.
Nice result Coluke!
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 5th September 2012, 01:59 AM   #710
scott wurcer's Avatar
Ciao,
L.
Good, be happy
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
