| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#61 | |
30 ohms is not uncommon. For example, two of my headphones (Senn HD800 and HiFiMan HE6) are 300 and 50 Ohms. Ic are limited in power handling but this is a discrete design and no such limitation need exist. Thx - RNM Last edited by RNMarsh; 23rd August 2012 at 07:16 AM. |
#62 |
You professional guys want for DIY audience to design a "discrete opamp" that you would use in your commercial designs?
Pavel Macura http://www.linkedin.com/pub/pavel-macura/4/783/637 http://web.telecom.cz/macura/audiopage.html |
#63 |
I hope we see a design come of this thread that is new or at least has some novelty, tweak or improvement over circuits most of us have seen shown here to death. That includes circuits that some experts believe is new but are available all over the internet and as old as 30 or more years. Possible ???
#64 |
I don't disagree with this, but as always, the devil is in th detail. Probably 80% of those designs have the wrong trade offs and are subsequently sub optimal.
Yes, i also hope we se something novel and with 8 trannies, it's going to have to be. :-) |
#65 |
Lots of talk, no action. sigh....
#66 |
True but one designer may optimize for a different reason which may not be obvious to you but important factor to him, so how can one judge that his way is not optimal afterall it is trade offs. For instance J Curl will optimize for wide bandwith but this is not neccesarily good for THD while Edmond will go out of his way to post lowest possible THD. Which one is suboptimal ??
I think the percentage is much smaller than that, probably less than 10 percent when it comes to commercially available equipment. |
#67 |
#68 |
So, some schematics a copied off a simple search. So much talk, so little action.
#69 |
#70 |
A few more for inspiration.
| Discrete OPAMP | audio-gd | Vendor's Bazaar | 27 | 20th September 2012 04:02 PM |
| discrete opamp help | blackpowderaudio | Parts | 0 | 16th December 2009 03:46 PM |
| THAT transistor headphone amp (250ma discrete opamp) design sanity check. | Russ White | Headphone Systems | 19 | 13th December 2007 12:52 PM |
