Discrete Opamp Open Design - Page 64 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 3rd September 2012, 01:11 PM   #631
zinsula is offline zinsula  Switzerland
zinsula's Avatar
Originally Posted by coluke View Post
I think the Ayre KX-R is based on the same concept.
L.
Input is J-Fets, gain stage is cascoded current mirrors. I don't know the output stage architecture though, but it seems to be a complementary JFetfollower. And balanced from input to output.
Charles Hansen in his posts leaved enough information to second guess, together with some magazine / website information ans pictures.
Check out the simplified (and strangely drawn) schematic here.
If you can't trust your ears, then CLICK HERE
Old 3rd September 2012, 02:04 PM   #632
scott wurcer's Avatar
We're back to "this probably sounds better" and the sound of feedback vs no feedback, amply covered in other in other threads.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 3rd September 2012, 02:19 PM   #633
coluke is offline coluke  Italy
Nope, Scott - didn't mean to cover once more the 'sound of feedback' topic, just described the reason why I tried that specific topology. Actually I've never been able to hear any difference between CL and OL version of the amplifier, provided the output impedance of the OL version is very low (say < 1 ohm).
L.
Old 3rd September 2012, 02:40 PM   #634
L.
That was meant in a more general sense. My original thought was along different lines like something that could be droped into a standard op-amp I/V or the Pacic-Pre phono. Keep it simple enough anyone can try it, nothing ventured nothing gained. Weather it uses 50 cents or $1.25 in devices was not the point.
Old 3rd September 2012, 03:52 PM   #635
bcarso is offline bcarso  United States
diyAudio Member RIP
Never say never - current-mode open-loop topologies are indeed capable of very low THD: I've built and tested a HP amplifier based on a pretty standard architecture (diamond in - transimpedance gain stage - high current diamond out) whose THD is in the -100 dB range (low order only) @ 1 kHz, 0 dBV into 30 ohm. And it sounds very good, too , but it is by far too much complex to be mentioned here (about 20 BJTs - basically a discrete CFA). You can easily convert it to closed-loop, and that's the reason why I gave a try to this architecture.
L.
Many of the topologies developed over the years for oscilloscope vertical amplifiers have very low distortion without global feedback. Feedback would have limited the frequency response. For a good coverage of many see Doug Feucht's book Handbook of Analog Circuit Design. The material has appeared here and there, including John Addis' contribution to one of the Jim Williams compendia, but afaik not as extensively in book form as Feucht's.
Translinear circuits with bipolars, which rely upon their very predictable characteristics, are routinely capable of order -80dB performance over a useful range of currents, and without additional local feedback (which improves things but slows them down). Barrie Gilbert is the foremost authority on these techniques, exploited in his eponymous multiplier.
I presented a current mirror in another thread that shows how to use cascoded FETs and floating bias sources with local feedback to realize low noise and distortion. It costs volts and power dissipation, but works well. It was to some extent offered for those who spurn bipolars, believing that there is some intrinsic inescapable "sound" there that they don't like.
Old 3rd September 2012, 03:57 PM   #636
PMA is offline PMA  Europe
PMA's Avatar
My next preamp design (if I ever get time for audio again ) would definitely be a CFA topology.
Old 3rd September 2012, 05:08 PM   #637
diyAudio Member RIP
Correction: Dennis Feucht, not Doug.
Old 3rd September 2012, 05:46 PM   #638
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default OP-Amp design
I also thought that was the point of coming to this forum as it was your input to do a new design (other than JC's) we (I) waited for and you delivered a very good one.
Has it now morphed into something else? Or, is it when a forum is done, it doesnt know how to end so it rambles on?
There are now plenty of Current-mode feedback designs being made on this DIYAUDIO and other sites. So there needs to be a goal for us to shoot for and not just ramble on about this or that circuit.
What are the goals for a new design?
Personally, I would now like us to try matching the performance of an opamp's high feedback with one with no gnfb. There are not many out there. Make it popular and easy as possible to make as the new goal.
Old 3rd September 2012, 06:36 PM   #639
RNMarsh's Avatar
PS - On the mid-level of gnfb circuit without dc servo... some have wondered just how stable over the long term it could be. After a year of service, I measured the dc offset at the output again and it is exactly where i left it a year ago..... .00x + or - a couple mV. -RNM
Old 3rd September 2012, 06:49 PM   #640
diyAudio Member RIP
Richard, in your Linear Audio article, Table 1 shows an entry for signal-to-noise ratio with the input shorted of - [sic] 135dB. Is this for a reference level of 1V rms at the output, into 30 ohms?
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
