Discrete Opamp Open Design - Page 61 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 1st September 2012, 12:01 AM   #601
bcarso is offline bcarso  United States
Originally Posted by scott wurcer View Post
JFET's have two temperature coefficients the Idss and the Vp are opposite in sign so there is a point of zero TC.
Thanks Scott. Yes, precisely. I suppose I wouldn't violate the fair use doctrine too much to copy the entire short section of Cobbold, as I believe it is long out of print.
Old 1st September 2012, 12:05 AM   #602
scott wurcer's Avatar
My copy walked years ago, Abebooks has it off and on for $70 or so.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 1st September 2012, 12:44 AM   #603
I just checked. Yes, OOP for sure. However:
BookFinder.com: Search for New & Used Books, Textbooks, Out-of-Print and Rare Books, which searches most of the sites (sometimes misses recent Amazon offerings though), has some a lot cheaper, probably ex-library even when they don't say that explicitly. That's my go-to for comparables on books, particularly when I find I have duplicate copies.
I love to look at the front free endpaper on books of that age, when I still used to write my name there. You can actually make out the spelling, easily. Not anymore
Old 1st September 2012, 06:32 PM   #604
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
As good a reason as any.
They also allowed for as few transistors as possible (no need for additional current sources for bjt biasing). It works very well --- if you find the matches as suggested; I got about 15-20% matches (.8v/1K) out of a batch of the jFETs.
Old 1st September 2012, 06:40 PM   #605
RNMarsh's Avatar
Default close enough?
Sorry Dick I misread the schematic (I read 51.1 Ohms on the penciled in values), you were aiming at 800uA but does not look too close.
.8v is about it but what I get from the circuit works extreamly well.... maybe could be even better... but was not needed. Maybe the data spec sheet is a little different from the devices I have... who knows. I didnt pursue it further when the prototype was as stable as it is. Thx-RNM
Old 1st September 2012, 07:59 PM   #606
Right, nothing gained by belaboring these details.
Old 1st September 2012, 07:59 PM   #607
RNMarsh's Avatar
An added final clarification: Note also that even though the matching uses .8 mA. With the values used in circuit (Re = 650 instead of 1K), the actual Id measures 1.1-1.2mA. Which is right where it needs to be for low TC.
-RNM
Old 1st September 2012, 08:12 PM   #608
Ironic that this returned Abebooks as the lowest available ~$11, in any case certainly worth replacement at that price.
Old 1st September 2012, 08:18 PM   #609
-RNM
Dick. you could use an avatar and nice pithy signature.
Old 1st September 2012, 08:29 PM   #610
Yes, despite the improvements in parts since 1970, it holds up well.
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
