| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#491 | |||
I was talking of temp. differences that are building up between dynamically self heating (I*R) components which are inside the same IC chip. The same thing that you were referring too here: Quote:
Is there an agreement on this? (bcarso says yes )Quote:
George
"Second Law is a bitch." - SY “Not to worry, audiophiles don't normally get past the Gate anyway.” - rdf |
#492 |
Hitsware, you're not far of the mark. For many decades, bipolar transistors were considered BETA DRIVEN devices. I spent my first 5 years designing with that approach.
It it worked pretty well, because in many, many applications, the design WAS beta driven. It is also true, today, more than many realize. As betas increased from let's say 20 to 100, then to 200 or more in many cases, then Vbe became significant, AND the real gain of the circuit was not limited by beta, but by the intrinsic Gm. The intrinsic Gm is .04mhos/ma. It goes up or down directly, depending on the quiescent current through the part. So, 1A would have a Gm of 40 Siemens (or mhos) In the early 70's the professors decided that beta was just a parasite and every attempt has been to ignore it. |
#493 | |
BTW, the noise contribution from that "resistance" is due to shot noise in the current referred to the input as a voltage noise density. Since the transconductance goes up directly with current and the shot noise goes as the square root, for low source impedances the overall noise goes down with increasing current, to a point that, among other things, is limited by the real thermal noise of the base spreading resistance. The contribution of the shot noise/transconductance makes the expression for the re contribution look like about that of a real resistor half the value of re, which is nice. It's funny to see people using very-low base resistance transistors at moderately low currents. The Marshall Leach-style common-base MC stepup circuit is an example --- but in his defense, he was also interested in prolonging battery life. |
#494 | |
#495 |
Bcarso, I think you will find that the actual voltage noise derived from Gm is Re/2. The derivation is not obvious, but at least it does track Gm.
#496 |
I already apologized for the typo. I meant 47 Ohm, but if to consider non - zero emitter resistance and non - infinite beta 26 Ohm indeed would be closer. But input resistance will be no higher than 10K, so of course you can't substitute directly in all cases.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#497 |
Fairly quaint way of putting it. Translinear circuits work even at beta of 1, oh well we've been over this before no need to repeat.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#498 | |
The local delta T will be dependent on the heat flow between the components of interest, not on the absolute temp. As I pointed out, if the thermal conductivity between the local chips changes as a result of absolute temperature, so will the delta T between them. I believe bcarso and I are agreeing, and we think differently from you. Perhaps when I get the time, I could draw it up, verbal descriptions are not easy to express nor follow at times. cheers, jn |
#499 | |
#500 | |
| Discrete OPAMP | audio-gd | Vendor's Bazaar | 27 | 20th September 2012 04:02 PM |
| discrete opamp help | blackpowderaudio | Parts | 0 | 16th December 2009 03:46 PM |
| THAT transistor headphone amp (250ma discrete opamp) design sanity check. | Russ White | Headphone Systems | 19 | 13th December 2007 12:52 PM |
