Discrete Opamp Open Design - Page 322 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old Today, 07:30 AM   #3211
keantoken's Avatar
Originally Posted by john curl View Post
We usually use ballast resistors, like 10 ohms in series with each emitter. 5 ohms would probably work OK.
Depending on Ic and Pd, you might not need any at all. BC3x7 are linear down to very low voltages so if you make Vce small you may not even need the resistors.
I made a thermal simulation to get an idea. Based on this you only get thermal instability beyond 20% if you violate Ic*Pd<860u for the TO92 package where the transistors are thermally coupled.
But I see no need to operate the BC3x7 at more than 1Vce so I don't think we actually need any ballast resistors at all.
Top traces are junction temperature, bottom traces are Ic for transistors 5 and 6.
Old Today, 08:01 AM   #3212
Send a message via Yahoo to linuxguru
Originally Posted by keantoken View Post
2: Almost nonexistant quasi-saturation - no better known transistor for low-Vce low-power applications such as C-multipliers, giving PSRR up to over 70db (the BC5xx follows closely at 60db, I wonder if newer BISS transistors from NXP could be better?). This also makes them ideal for current mirrors where gain is lost through quasisaturation (BIG mistake to use high-voltage japanese transistors here).
I guess this applies to both the NPN and PNP, as well as the SMD versions that use the same die - BC807/BC817. I'll give them a try in a current mirror shortly - I've used BC847C/857C in current mirrors earlier and they seem to work OK, but maybe the 807/817 are good substitutes with lower noise.
Old Today, 08:14 AM   #3213
Originally Posted by stormsonic View Post
Your work have inspired me to start measuring transistors in my parts bin. Found another decent performers, Zetex ZTX651/751.
How did you measure the noise performance and what numbers did you get?
1mA & 3mA would be good
Old Today, 08:18 AM   #3214
keantoken's Avatar
Oops, I discovered the last simulation went into runaway after 10 minutes. The actual number is Ic*Pd<460u, and you'll probably want to stay well under this. 10mV (1R at 10mA) degeneration moved it back up to 860u.
Old Today, 08:51 AM   #3215
Originally Posted by gerhard View Post
Do you mean me? "Joachim Gerhard" and "Gerhard" are different entities :-)
My apologies Dr. Hoffmann
Iono is indeed impressive.
If I still had a working turntable I would be tempted to ask to borrow it for some listening tests. I still have a couple of MC cartridges.
Discrete OPAMP audio-gd Vendor's Bazaar 27 20th September 2012 04:02 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
