Discrete Opamp Open Design - Page 300 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 31st October 2013, 05:42 PM   #2991
Send a message via Yahoo to linuxguru
Originally Posted by rsavas View Post
I have BF862 is my stock. Have you looked at KSC1845/KSA992 and the smt versions fjv992/1845?
Thanks, I'll PM you later regarding the BF862. I've used the original NEC 2sc1845/a992 extensively, but had no idea until now about the Fairchild SMD versions - will check them out.
Old 31st October 2013, 09:40 PM   #2992
This is a simulation schematic of a simplified 4-BJT Ken's Diamond as the output stage - it's derived from the 6-BJT Ken's Diamond, but the CFPs at the output have been reduced to single BJTs, thus reducing the BJTs in the output stage to 4. The voltage reference has also been opportunistically obtained from the VAS CCS without any additional device.
It seems to simulate with a few dB lower H3 than the Diamond Cascode at similar output stage bias of around 8 mA. It still needs further analysis of stability, phase margin, overdrive and clipping behaviour, PSRR, etc., but it looks to be a viable contender for a Class-A output stage for the FET990.
File Type: jpg lf06s_v1.4_kens_dmd_simple_4v600r_fft.jpg (84.1 KB, 795 views)
Old 1st November 2013, 06:01 AM   #2993
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Demian and I both live in Northern California and have worked with and known each other for many years.... we can measure just about anything. We would be happy to see what difference there might be between your SIM VFA and an actual built unit.
Thx-RNMarsh
Old 7th November 2013, 04:31 PM   #2994
grhughes's Avatar
Has anyone built a Wurcer preamp with real parts and tested it on a bench? Thank you? Ray
" Polarities are seldom aware of their polarness." Prospero
Old 7th November 2013, 04:44 PM   #2995
grhughes's Avatar
I've laid out a board with to92 thru hole parts but I have some questions. Do the input jfets require shielding around the gate pads? Some jfet input opamps require this. Also are catching diodes on the output necessary as part of the diamond compensation. They are not on any of Scott's schematics but appears on others. Also moving the offset null to the resistor leads of the positive current source requires many more parts than putting it where Scott originally had it. Just the things I'm wrestling with. Thanks Ray
Old 7th November 2013, 04:56 PM   #2996
RNMarsh's Avatar
Hi Ray,
This was designed by SW and so should use his schematic and his Ok on any changes or additions (like diodes on output). Others' mods/changes to it can have the others' pcb made. I would like to use the design exactly as Scott created it. Then others designs can have their pcb for it made.
The ring around the inputs (jFETs) is a good idea so we can try using it as a guard ring.
Thx--- I have been waiting a long time for the thru-hole version. :-)
-RNMarsh
Old 7th November 2013, 05:09 PM   #2997
grhughes's Avatar
Thanks Richard. I've used Scott's two board sandwich idea and his schematics only. I haven't transferred it from the initial drawing to the computer. Just mulling around options. Ray
Old 17th December 2013, 02:03 AM   #2998
RNMarsh's Avatar
Where is everything now? Its been awhile.
Thx-RNMarsh
Old 17th December 2013, 02:19 AM   #2999
grhughes's Avatar
Hi! I have it laid out. I'm trying to reduce trace size on summing points by moving around some parts. It's 2 inches by 1.5 inches. I'll transfer it to computer as soon as my newly ordered software comes. My current software needs upgrading and crashes. I would like your opinion. Ray
Old 17th December 2013, 02:32 AM   #3000
RNMarsh's Avatar
OK.
and - I am ready to measure a working SWOPA when ever... .
Thx-RNMarsh
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
