Discrete Opamp Open Design - Page 30 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th August 2012, 09:35 PM   #291
john curl's Avatar
If you can't get the parts, find a good IC.
For the record, I did a simple Google search for two complementary jfets, the J113 and the J175. I found both of them for sale under $0.50 each. You just have to buy a bunch of them and select them out. If you cannot invest $100 for this, then buy an IC. It will give you better performance.
"Condemnation without Examination is Prejudice"
Old 26th August 2012, 09:43 PM   #292
coluke is offline coluke  Italy
Originally Posted by ChocoHolic View Post
In fact I appreciate much more to see a sim and measurements on a real set up of with average components, (...)
Agree - then I think you're going to appreciate the open-loop CF amp I'm talking about in this post: Marsh headphone amp from Linear Audio
Too many bjts to be mentioned here, but it works really fine with pretty standard and cheap * unselected * devices, and this was exactly what I was looking for.
L.
Old 26th August 2012, 09:43 PM   #293
john curl's Avatar
Now why did I choose these devices? They are representative of still available devices that can still be purchased, that Levinson used in the early days. OF COURSE, the Toshiba devices are easier to match, lower noise, and higher Gm. But if you can't get ANYTHING (Toshiba jfet), then alternatives should be chosen.
Old 26th August 2012, 09:49 PM   #294
john curl's Avatar
I would also point out that complementary differential works best when complementary jfets are used. Perhaps a different, single jfet pair, circuit would be best.
Old 26th August 2012, 10:06 PM   #295
dirkwright's Avatar
Originally Posted by Johnloudb View Post
That's the spirit! ... Just kidding ya Nice circuit.
A DC servo addition would be nice. If not would probably want a cap at the output. DC can be dangerous to speakers as I'm sure you know.
I think the spec was for less than 2mV of DC offset, wasn't it? I can't remember.
This isn't my show, I just wanted to make a contribution, however small it may be.
Old 26th August 2012, 10:07 PM   #296
john curl's Avatar
This is a recommended alternative to a complementary differential fet design. This design was used in several professional mixers as well as in three 30ips master analog recorders.
sorry about the bad copy, the original schematic goes back to about 1977.
Old 26th August 2012, 10:07 PM   #297
These can be considered ' complementary ' ?
http://www.fairchildsemi.com/ds/MM/MMBFJ177.pdf
http://www.fairchildsemi.com/ds/J1/J111.pdf
Old 26th August 2012, 10:20 PM   #298
john curl's Avatar
Yes, these are the devices. Many manufacturers still make them. However, they have a LARGE Idss spread, so only dumb luck will match the P's to the N's, but that is not very important, within limits. Just good N to N, and P to P is the most critical.
Old 26th August 2012, 10:21 PM   #299
EUVL is offline EUVL  Europe
The J17x series are rather noisy parts.
Patrick
xen-audio.com
Old 26th August 2012, 10:22 PM   #300
john curl's Avatar
To cite an old saying: 'You can't afford 2mV offset!' '-)
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
