Discrete Opamp Open Design - Page 298 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 10th September 2013, 05:27 AM   #2971
Send a message via Yahoo to linuxguru
Originally Posted by EUVL View Post
As I posted earlier, our team built a 10x10 prototype of the Kaneda circuit.
But it is too small to solder for most, and too tidious to adjust to make it a public project.
While I am certain the latter designs are equally nice in performance, they become too complex and hence large to build in 10x10 footprint.
This is not quite 10x10 - it's about 12.7mm by 15 mm, but with no additional vias and almost entirely on a single side (the rail-to-rail bypass on the solder side is optional, in which case this is a pure single-sided layout). It could be crunched down a bit more by using SOT323, 363 and dual JFETs, but as it stands now it represents a reasonable tradeoff between ease of assembly and size. The dual BJTs shown are Rohm duals that are readily available.
The schematic is the Kaneda variant shown in the previous post.
Old 11th September 2013, 09:34 PM   #2972
Default High Voltage Depletion FETs
Guru Wurcer, I believe one of your original plans for SWOPA was to use the input stage for a 100W 8R amplifier.
This would need High Voltage Depletion FETs for the input cascodes.
I think some suitable devices including some depletion MOSFETs were unearthed.
Would you or anyone else remember what these were ... especially if they have good SPICE models?
Old 12th September 2013, 04:07 AM   #2973
Supertex makes (or used to make) a line of depletion MOSFETs like the DN2540, etc. There were probably a few in TO92 packages. Other vendors were Ixys and Clare, but not sure of current production status.
Edit: Apparently still in production at Ixys (which owns Clare), in very nice SMT packages:
http://www.ixysic.com/Products/FET.htm
Infineon also has some BSS family parts like the BSS126, 129, 149, 159, 169...
All of these are n-channel only - I don't think there has ever been a depletion-mode p-MOSFET fabricated.
There are also a few Japanese n-channel depletion JFETS with (relatively) high Vds(max) ratings - Toshiba 2sk373 at 100V, and a Sanyo part that does 80V, among others. Both are nearly obtainium now.
Old 12th September 2013, 05:32 AM   #2974
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
ALD has a helpful paper on depletion mode FETs. I tried to upload it but its just too big for the filesize limit. Google will find it (Advanced Linear Devices).
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 3rd October 2013, 11:48 AM   #2975
Hi all,
A potentially "quick" question: Any of these designs have GBW of >= 100 MHz and low noise data?
Thanks for looking and maybe replying ;-)
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 3rd October 2013, 12:09 PM   #2976
SWOPA and kgrlee's FET990 variant could get to 50 MHz GBW, maybe more - but 100 MHz is probably outside their envelope. All the others are slower, AFAIK.
Low noise is not a problem - any of the JFET-input designs can use low-noise devices and surpass almost any monolithic.
Old 3rd October 2013, 07:07 PM   #2977
dchisholm's Avatar
Originally Posted by linuxguru View Post
SWOPA and kgrlee's FET990 variant could get to 50 MHz GBW, maybe more - but 100 MHz is probably outside their envelope . . . .
I recall playing with simulations that got GBW up to the 50 MHz - 60 MHz range by using fast transistors and adjusting passive component values. I could tell it was starting to get sensitive to active device parameters, so might require some pre-selection or matching of active devices to reach that performance level on a physical assembly.
100 MHz might be possible if you're willing to give up unity gain stability. The ability to modify the compensation scheme to suit an application is one of the attractions of a discrete design like this. That's why I brought out the main compensation node to an external connection when I did my PWB layouts. (See Posts #2909 and #2656.)
Dale
Old 4th October 2013, 03:38 AM   #2978
What application needs this?
Old 4th October 2013, 07:58 AM   #2979
keantoken's Avatar
An oscillator of course! Why, you can do that with just one Vfet (not sure about the low noise part).
But, it would be rather interesting to try to design an audio circuit with that goal.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 4th October 2013, 06:05 PM   #2980
Hi all,
& thanks for replying. An oscillator would be interesting although I don't really know how to design one with low THD which would be my aim here. In this case I'm mostly curious - maybe you have a part of your mind that often "searches" for new & better solutions - this is what happened here as I've found this thread's designs interesting though haven't had the time to read all of it.
Greetings,
Jesper
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
