Discrete Opamp Open Design - Page 287 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 19th March 2013, 03:46 PM   #2861
scott wurcer's Avatar
Originally Posted by kgrlee View Post
Where is this thread please?
I see Mike is back. I have two weeks to a tapeout and then I should get time to rev my boards and take more measurements.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 20th March 2013, 02:19 AM   #2862
Originally Posted by PHEONIX View Post
Hi Frank,
Does this go for the Intel/AMD chip and socket in your PC.
Perish the thought of ever using a valve in a socket !!
Old 20th March 2013, 02:38 AM   #2863
fas42 is offline fas42  Australia
Banned
Which is why I would approach the concept of a valve amp very, very carefully ... things are very different in the latter world, lots of heat, temperature cycling is ferocious, chunky connectors, high voltages - like going from a chamber music performance to a disco, electrically speaking ...
Frank
Old 20th March 2013, 05:44 AM   #2864
benb is offline benb  United States
I think I've found a test signal:
WALTER MURPHY- A Fifth of Beethoven (extended version) - YouTube
Old 21st March 2013, 07:47 AM   #2865
Banned
How so? Fairly straightforward mix of classical and light jazz acoustics, shouldn't be too hard ...
Now, if I want a decent stress test I would try some 90's Joe Cocker, "You Can Leave Your Hat On" era material: big, big acoustics, full on big band sound -- this is sound that can subjectively grab your house and threaten to crush it like a cardboard box if it's reproduced well at high volume ...
Frank
Old 28th March 2013, 12:40 AM   #2866
Banned
Scott's still on to it, but not a single other person has hacked one of these to see what they think of it ... ?
Frank
Old 28th March 2013, 06:55 AM   #2867
Send a message via Yahoo to linuxguru
SWOPA is a bit too complicated for me, so I went with a Class-A folded Kaneda with 7 actives in 11mm x 14mm SMD. I've built over a dozen prototypes with slight tweaks and parts changes, and it's now stabilized with tight offsets.
I also did a Class-AB FET990 derivative in 15mm x 15mm, and the first batch of boards is in transit to me. These can use BF862 or 2sk209 inputs, and SOT89 outputs like the 2sa1213/2sc2873.
I also have an updated schematic and layout for the FET990 with jcx's clamp-diode bootstrap idea, also in 15mm x 15mm, but I'll hold off on fabrication those boards until the existing board is fully validated and auditioned.
I'm still searching (in simulation) for a simple topology with low transistor count and acceptably good performance. Nothing beats the FET990 derivatives to date.
For the output-stage, Ken Peter's non-switching Class-B with Schottkys is a very strong contender for low-bias current applications - it works reasonably well down to 1 mA bias and maybe lower. However, it does best with a high-performance monolithic opamp as the gain stage driving it.
Old 2nd April 2013, 01:01 PM   #2868
Have you a link to this please.
Old 2nd April 2013, 01:35 PM   #2869
grhughes's Avatar
I'm going to risk sounding off as a audiophile who is not an EE, but why hasn't someone advocated an all npn Class A output stage. I thought that pnp transistors typically had much higher c-b capacitance which slows their switching speed for Class B-AB stages. I read that the Burr Brown OPA604 had an all npn output state. So why in a no holds barred design are we possessed with efficiency? Please be kind! Cordially, Ray
" Polarities are seldom aware of their polarness." Prospero
Old 3rd April 2013, 03:15 AM   #2870
If your going to use Joe Cocker as a test use 1985's Shefield Steel with Sly and Robbie as the rhythm section. Not a commercial hit, but Joe doing great dynamic music instead of the commercially viable Musak he's been stuck with for decades.... Now back to our program
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright 1999-2017 diyAudio
