Discrete Opamp Open Design - Page 268 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 29th January 2013, 08:35 PM   #2671
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Re making a th circuit --- sm for the input transistors is OK and the rest th. Size isnt important... meaning it doesnt have to be the absolute smallest possible size. Use "standard" part size. That way most brands will fit. Is a kit being made of pcb and parts? Or better, yet assembled pcb? If not, it doesnt matter what is in the BOM.... Susumu or otherwise.
-RNM
Old 30th January 2013, 08:04 AM   #2672
Send a message via Yahoo to linuxguru
Link to a prototype folded Kaneda-style Class-A DIP8 single opamp module, approx. 11mm x 14mm in size:
kaneda preamp
The resistors are 0603 size; all actives are SOT23, except a Rohm dual-PNP in SMT6; and the rail-to-rail bypass is a Panasonic ECHU PPS film-foil in 1210 size, mounted on the underside. All signal traces are on the component side only, allowing the possibility of a single-sided board in future revisions.
I cheated on the prototypes shown, by using a Zetex ZRA125 1.25V bandgap reference instead of the BAV99 dual-diode in the schematic - I just wanted to be sure that the first prototypes would work, i.e. produce some sound, which they did on the very first test.
Old 31st January 2013, 12:33 AM   #2673
RNMarsh's Avatar
Excellent article on sm film resistors by Vishay.... EE Times; News and Analysis. 1/30/2013
www.eetimes.com/electronics-news/4199812/Strengths-and-weaknesses-of-common-resistor-types
Be sure to read comments section as well.
-RNM
[As I suspected, film thickness varies in thin film for reasons explained in article]
Old 31st January 2013, 01:13 AM   #2674
jcx is offline jcx  United States
Thin film resistors consist of a metallic deposition (made by vacuum deposition or sputtering process) with a 50 to 250 angstrom thickness on a ceramic substrate [recall that one angstrom () = one nanometer = 10-10 meter].
I can spot that as wrong 15 min after 3 drinks with dinner, search doesn't find CVD in the article either - are they sure they're up to date on R film tech?
Old 31st January 2013, 01:21 AM   #2675
bcarso is offline bcarso  United States
diyAudio Member RIP
poor old Mr Angstrom-unit (and Mrs Nanometer isn't doing so well either)
Old 31st January 2013, 01:41 AM   #2676
tvi is offline tvi  Australia
tvi's Avatar
A little more insight
thin film resistors versus thick film resistors how they compare
However, the heat generated during laser trimming causes micro-cracks on a thick film resistor and therefore affects the short term and long term stability. Thin film resistors need less laser power than that needed for thick film resistor. Thin film resistors do not exhibit micro-cracking during laser trimming. Consequently thin film resistors show superior stability and noise performance.
The small part of ignorance that we arrange and classify we give the name of knowledge.
Ambrose Bierce
Old 31st January 2013, 04:35 PM   #2677
myhrrhleine's Avatar
Originally Posted by scott wurcer View Post
This is common, the output impedance rises with frequency so it looks inductive and a cap load can make it oscillate. Usually a small R like 25-50 Ohms helps. The addition of a capacitor from the output back to the inverting input provides AC feedback without "seeing" the cap load. This stuff usually helps well outside the audio band.
BTW even an open-loop emitter follower can oscillate, but that is usually 100's of MHz and not seen easily on the scopes DIY'ers often use.
Hi Scott,
The information Ive seen showed improvement for extremely low distortion levels, like around -100db.
Is that caused by oscillations?
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 31st January 2013, 05:48 PM   #2678
scott wurcer's Avatar
Originally Posted by myhrrhleine View Post
Hi Scott,
Can't tell without a careful look at before and after, but in my experience when oscillating at a low level at several hundred MHz it is more pronunced.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 31st January 2013, 06:50 PM   #2679
S.A.G. is offline S.A.G.  Italy
Default Transistor selection
I'd like to go full SMD to avoid the somewhat complex assembly of TO92 devices in the output stage. OTOH, I'd like to retain the thermal tracking feature of the PTH configuration while driving low loads.
I've been looking for dual NPN/PNP transistors in SMD packages capable of some power dissipation and the only parts that I came up with are the NXP PBSS4041SPN:
http://www.nxp.com/documents/data_sheet/PBSS4041SPN.pdf
It seems to me that those parts are designed for (static) switching rather than linear operation. They are also comparatively slower than 2N4401 / 2N4403, for instance.
Questions for the Semiconductors Gurus:
- are those parts any suitable for the output diamond buffer?
- any similar, better, parts?
Thank you.
Giorgio
Old 31st January 2013, 07:17 PM   #2680
RNMarsh's Avatar
Hi Scott,
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
