Go Back   Home > Forums > Source & Line > Analog Line Level
Old 15th January 2013, 06:51 PM   #2601
Originally Posted by jan.didden View Post
... flying off the handle ?
Re: thinking: I once had a manager, who saw me siting at my desk, hands folded behind my head, ask what I was doing. "Thinking".
Said he: "I 'm not paying you to think, I am paying you to work". And I swear, he was dead serious.
jan
This is an excellent joke ! I need to remember it so that I can tell it to other people.
P.S.: I'm not saying it didn't happen, just that the story is very funny.
Old 18th January 2013, 04:38 PM   #2602
grhughes's Avatar
Location: Cubicle Sweet Cubicle, Springfield, Missouri, USA
"......I noticed the 357 Ohm resistors could be a tad larger the ratio to the position held by the 243 Ohm one should be closer to 5/3, this only adds 400uA in that branch which does not do much and comes out in the trim." S. Wurcer
Is 383 ohms too much? I'm hard pressed to find those Panasonic DMG/DMC2040020R at either Mouser or Digi-key. Thanks, Ray
" Where's the KABOOM? There is supposed to be an earth shattering KABOOM." MM
Old 18th January 2013, 05:06 PM   #2603
Send a message via Yahoo to linuxguru
Originally Posted by grhughes View Post
... I'm hard pressed to find those Panasonic DMG/DMC2040020R at either Mouser or Digi-key. Thanks, Ray
NXP has BC8xx in dual NPN/NPN, NPN/PNP and PNP/PNP, both matched and unmatched, in SOT363. If you want a larger package with higher power dissipation, the Rohm IMX- (NPN/NPN), IMT- (PNP/PNP) and IMZ- (NPN/PNP) series in 6-pin SC74/SMT6 packages fit the bill nicely. Be very careful with the pinouts on the Rohm packages, though - some smaller packages have the standard 123456 pinout, while some of the SMT6 packages have 321654 (reversed) pinout.
Old 18th January 2013, 05:54 PM   #2604
scott wurcer's Avatar
383 is fine, and all those general purpose duals should be fine, I've used the NXP devices before.
I just bought all the Panasonic ones from Digi-Key last week?? Try a search for Panasonic and the package you want. The numbers get long maybe I missed a digit.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 18th January 2013, 07:32 PM   #2605
PHEONIX is offline PHEONIX  Australia
Hello Scott,
I like the take on the hardware.
What are you using to measure the distortion and is it possible to measure the whole stage including the input stage for distortion.
Old 18th January 2013, 08:00 PM   #2606
grhughes's Avatar
Thanks guys! Is it going to be necessary to add a choke trap output filter (back door filter) to the output of the preamp driving a power amp with about 20 feet of cable? I'd like to avoid the back door trap filter if possible. I guess I'll just have to try it. Ray
Old 19th January 2013, 07:46 AM   #2607
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
SW--- is this InterFET part any good? --> jFET P/N IF3601/02 (.3nV). -RNM
Old 19th January 2013, 07:49 AM   #2608
RNMarsh's Avatar
Any time you use an impedance in series with the output (build-out R or inductor) it raises the Z of the whole cable interconnect which then makes the cable more susecptable to emi/rfi pickup. place such at the load end, if possible. -Thx RNMarsh
Old 19th January 2013, 11:13 PM   #2609
While Mr. Marsh is correct about the 'input' end being the more important, EMI/RFI can be injected into outputs too.
Clip on ferrites for computer cables are an inexpensive aid if you have problems. They need to be as close to the end of the cable as possible but outside the box.
Best with ceramics AT the input/output sockets too.
________
Mr. Hughes, I'll leave Scott to answer the question about acceptable capacitive load but you might want to look at AD797 datasheet for how this might be presented. It will be affected by the compensation capacitor too.
Belden 9451 has 35p/ft conductor/conductor and 67p/ft conductor to shield. Nominal Z is 45R but 'best transient' response over a long length is with about 90R.
Yes the extra resistance will degrade EMI/RFI but only if you don't have the ceramics at the sockets.
Old 19th January 2013, 11:38 PM   #2610
fas42 is offline fas42  Australia
There's a lovely snippet in the 'bible', H & H: opamp closed loop impedance rises with frequency, say 10 to 100 ohms at 1Mhz. Nearby, digital circuitry is slewing at 0.5V/ns. We want an error coupling of less than 0.1mV to appear in the analogue.
What does the capacitance between those two signals have to be below to achieve that? 0.02pF, something everyone here I'm sure will know how to maintain ...
Frank
Discrete OPAMP audio-gd Vendor's Bazaar 27 20th September 2012 04:02 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
