Discrete Opamp Open Design - Page 241 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 17th December 2012, 05:37 PM   #2401
wahab is offline wahab  Algeria
Fear of the technology being copied is a cover.
A firm like Hitachi buy all kind of chips , not only their own,
and i would be surprised that AD or other firms would refuse to
deliver accurate models if such a firm was to buy their products.
Disposal of accurate models is instrumental in reducing dramaticaly
designs costs as well as a time to market deadlines so the manufacturers
message is clear : buy our chips for significative $ amounts and you ll
get the good models , do otherwise and you ll soon be bankrupt...
Old 17th December 2012, 06:19 PM   #2402
RNMarsh is online now RNMarsh  United States
RNMarsh's Avatar
I see. Keep the design models inhouse. Be involved in the design ... least one become just another $1B fab house. With that extra parts cost and a NDA one has business security. It works for awhile that way. Every stage of product development goes to a specialist.... sort of like the medical industry. Makes the books look good for stock holders. Its good for everyone but the end user who ends up spending more. There is a trend in Asia to be vertically intergated, though. Only last stage/fab farmed out.... sometimes.... with heavy stock investment in the fab/factories as well. Interesting times. We shall see.
It means we need to do some tests on our own for the parameters important to modelling audio designs. We dont need everything that an IC design team will come up with... just what is needed for accurate modelling for audio designs. What is needed then -- what are they and which ones are most often missing or not accurate? And, how are they measured? THX-RNMarsh
Old 17th December 2012, 10:37 PM   #2403
Originally Posted by scott wurcer View Post
Gee Richard they are right there on the web site. This is the basis for them, http://www.analog.com/static/importe...tes/AN-138.pdf.
Thanks for these Scott & Frank. My excuse is I'm new to dis internet stuff.
www.analog.com is indeed a treasure trove.
Dunhill, you might find their Analog Filter Wizard useful in your quest for the ultimate filter OPA.
If you're very clever you can spot part of the problem in the credits.
OK. I give up. Is smarty-pants Wurcer going to tell us not-very-clever-unwashed-masses the answer?
I spent time in da old days, reducing Boyle models from the TI & Philips models so I could use them in my home brewed linear circuit analysis package. Was always disappointed to find how crude they were. Of course, I couldn't sim non-linear stuff but I trusted my own stuff for stability in dem days.
So it's likely the simplified models will give me exactly what I want. There's also a couple of ANs & tools on driving capacitive loads.
Old 20th December 2012, 08:15 PM   #2404
dchisholm's Avatar
Default Is There An Error in Post 1568 Schematic?
I have been running LTSpice on the the topology shown in Post 1568. (Which I believe is the latest version.)
From looking at the circuit's gain-phase plots I think there may be a drafting error in the diagram posted at #1568. The secondary compensation pole-zero networks may be connected to the wrong sides of the differential input stages. See atch image "Post1568_Possible_Error.png".
I have also attached simulation result screen shots (and the native LTSpice files that generated them) showing the behavior of the Post 1568 circuit as-drawn. In particular, look at the unstable phase margin (MINUS 12 degrees) at the unity gain frequency.
Following posts will show results for modified versions of Post 1568. If the Post 1568 circuit topology should be modified to improve performance, I'd like to know because I'm laying out a PWB and don't have enough acreage to allow for compensation networks in BOTH locations!
Dale
Old 20th December 2012, 08:24 PM   #2405
dchisholm's Avatar
Default Corrected (??) Circuit from Post #1568
Here's how the performance improves when the compensation networks are placed on the other side of the input differential amps, and values adjusted for the higher values of emitter resistor. The low frequency gain-bandwidth isn't affected, but the unity gain phase margin improves considerably to PLUS 60 degrees. (The unity gain frequency decreases from around 33 MHz to about 13 MHz.)
Dale
Old 20th December 2012, 08:37 PM   #2406
dchisholm's Avatar
Default Tweaking Modified Compensation Scheme from Post 1568
And here is an example of what may be feasible with this circuit. It actually looks like a low-frequency gain-bandwidth of 50 MHz or more (with unity gain phase margin on the order of 30 degrees) might be practical without resorting to heroic efforts of selecting components, customizing each unit with the aid of a network analyzer, etc. (We started with an RF JFET, after all!)
By the way, I used the BC550/BC560 models from Bob Cordell for all of the BJT's in this sequence of simulations. I am quite aware that other models, and different component values, will give differences in specific result values - my major concern is determining where the compensation networks should be placed so I can proceed with the PWB layout.
Dale
File Type: png Post1568_Comp_Moved_and_Tweaked_Gain-Phase.PNG (216.0 KB, 426 views)
Old 20th December 2012, 08:38 PM   #2407
scott wurcer's Avatar
Dale
I'll check tonight, it could depend on the particular device choice. Unity gain stability can be a tough issue and lots of small things can matter.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 21st December 2012, 10:31 PM   #2408
Dale
They are correct for my device models, and in any case boosting VAS drive at high frequencies is what you want (the JE990 has a complex network here). I'm sure their values were empirical. I suggest that since as is at gains > 10 there is no problem you could fit short lines to each point and cut the unused one. I don't think the last word on unity gain operation will be until a good tight layout is exercised.
Old 21st December 2012, 11:08 PM   #2409
To summarize these are the values that ended up in my breadboard. I am showing them just to be exact there is certainly some latitude possible without changing much. The FETís are 2SK170 cascoded by J310ís, the bipolar are all 2N4401/4403ís, the diodes 1N4148, bias set at 25mA total. I measured AOL and THD at 10Hz, 1KHz, and 20KHz. Everything looks good, damping the input and adding the 15pF made everything behave. The AOL at 10Hz was 400K and at frequency was right on simulation same for the third harmonics, everything above the thirds far down. Vos was 7mV (simulation of all perfectly matched devices was 3.8mV) with NO matching of any devices. This made for a slight increase of seconds over the sims, Iím sure matched devices and an offset trim would fix this. Yes these were all single devices pulled at random out of the bag.
Before I forget, thanks to EUVL, there is another useful JFET. The PMBFJ620 looks to be a dual high Vp BF862 type device, perfect for the cascode spot (Iím not sure the highish Vp works on the input devices). But a big heads up on another matched pair of low noise JFETís with low capacitances (cheap, cheap too). Thank goodness for the emergency broadcast network.
I need to take a break on this for a while, we have a two week shutdown so Iím sure I will find time to do an SMT layout and I now have access to a reflow oven.
Old 21st December 2012, 11:15 PM   #2410
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
PMBFJ620 is 6nV/sqrt device I sent you samples several years ago
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
