| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#2371 | |
#2372 | |
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#2373 | |
BTW: I have designed two new discrete op amps (or building blocks), one CFA and one VFA. They both have (to quote Brad from the BH thread) "precisely equivalent positive and negative slewing/settling behavior" I have also designed two new preamps using these building blocks, the simulated results are very promising. Have to build them to confirm the simulated results. One has balanced differential input, balanced "singel ended drive differential" output. The other has balanced differential input, balanced differential output. Both can of course also be used as se input, se output, se input, diff output and diff input, se output. Attached some simulated results: Preamp 1: (10V pp sinus out into 600ohm (less than 0.1ppm THD)) Preamp 1: 20k Square se out Preamp 2: 20k square diff out Both are using BF862 with BF545C as cascode Cheers Stein
Look behind you! remember that you are only a man. Last edited by stinius; 14th December 2012 at 09:51 PM. |
#2374 |
On this general subject of current versus voltage as variables, I was reminded of some help I gave to a visiting Bell Labs physicist at UCLA whose specialization was plasma physics. It was a very strategic bit of benevolence on my part although I didn't know it at the time.
He was lamenting, as I loaned him my copy of the RCA photomultiplier tube handbook that was missing from the engineering library, that he just couldn't get his equipment up and running for long, if at all. So I paid a visit to his lab and looked over some of the setup. It was difficult to suppress a few chuckles, as there were so many things effectively booby-trapped. For openers, the high voltage power supply was a huge and quite lethal thing capable of iirc a few 100mA up to several kilovolts Yet it was to be used to drive dynode voltage divider strings for the PM tubes, which drew at most a mA or so.Then, the tube base he had turned out to have a 50 ohm termination resistor buried inside, anticipating pulse-counting photometry, but he was doing low-frequency "d.c." photometry. He initially didn't believe me when I said I measured 50 ohms. We got rid of that, or found a tube base that didn't have one. But the funniest part: all of the connectors in the system were BNC. High voltage, opamp supply voltages, signal inputs, signal outputs . So of course the grad students were frying everything on a daily basis.Anyway, I said Let me make something up for you that's a bit more bulletproof. I wired up an opamp (I think it was an ADI module) and used a feedback R and a little feedback C, tailored to the cable capacitance. I found an incompatible connector for the HV, and reserved normal BNCs for input and output. And I put a little safety resistor in series with the input, along with some clamp diodes to common ---I think it was 1k. If someone still managed to get HV to it, it would fuse before the opamp blew. The problem was, that the physicist could not wrap his head around the appearance of the schematic, which, with the input protection resistor, looked like a voltage-input inverting amplifier with tons of gain (I think the feedback R may have been 1Mohm). I explained repeatedly that a PM tube had about the highest intrinsic output impedance of anything in routine use, and in that sense looked very close to an ideal current source. But even so, if he wanted to persist in viewing the amp as having a voltage gain of -1000, that still "worked": the, say, -10uA of phototube current would develop about -10mV across the 1k, and the gain of -1000 would then cause the output to be about +10V (given adequate opamp open-loop gain). It wasn't the most felicitous way to view things, but that explanation, and the fact that everything worked and had good signal-to-noise ratio, seemed to satisfy him. |
#2375 | |
I added a few circuit elaborations to the basic folded Kaneda, and the performance improvement is dramatic. 1. Added a Class-AB push-pull buffer to reduce loading on the totem-pole VAS. 2. Added a Hawksford Cascode to the PNP driving the upper NPN of the totem pole - this is the game changer for the VAS. 3. Cascoded the LTP JFETs - contributes a few dB in THD20 reduction. It's now at 13 actives, but all the additional devices are worth it. Compensation tweaks, clipping/overload, stability, etc. haven't been investigated. Here's the basic circuit, which I'll call the Folded Kaneda-Hawksford. Last edited by linuxguru; 15th December 2012 at 04:03 AM. Reason: attachments |
#2376 |
#2377 |
LTSpice says that THD20 at 4V into 600R at output stage bias of about 12 mA is -120 dBr. Even if it's lying, it's pretty good - H2 can be reduced further by replacing Q2 with a diode and tying the bases of Q1 and Q3 together. However, I'd prefer higher H2.
#2378 |
The JFET model is the same as the 2sk117/184/209/2145 posted earlier - you can use the 2sk170 model in a pinch.
Here are the BJT models, downloaded from Infineon and Rohm respectively. Edit: The output stage models are not critical - I cross-checked with NXP BCX56 and BCX51 models: Icq is within 15 per cent, and THD20 is within a few dB of the Infineon models attached. Last edited by linuxguru; 15th December 2012 at 05:19 AM. Reason: addendum |
#2379 |
#2380 | |
| Discrete OPAMP | audio-gd | Vendor's Bazaar | 27 | 20th September 2012 04:02 PM |
| discrete opamp help | blackpowderaudio | Parts | 0 | 16th December 2009 03:46 PM |
| THAT transistor headphone amp (250ma discrete opamp) design sanity check. | Russ White | Headphone Systems | 19 | 13th December 2007 12:52 PM |
