| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#2341 | |
#2342 | |
Super TIS is a ve..ery specialised application that only shows pp zillion THD into 50M & greater loads.
#2343 | |
Also, thanks for the information on how to qualify the design. I'm sure I'll have more questions later, but the gives me enough to go on for now. Last edited by luvdunhill; 9th December 2012 at 07:03 PM. |
#2344 | |
Dale |
#2345 |
#2346 | |
The PZTA is heading in the right direction though, though I had to null out way more DC offset than with the other two candidates. Again, I used the NXP models. I wonder what qualities of the PZTA make it perform better than the BCP? If I can figure that out then I could see if there are models that perform even better. |
#2347 |
#2348 |
#2349 |
#2350 | |
Do you have a copy of Dimitri's "Enhanced cascode Article". |
| Discrete OPAMP | audio-gd | Vendor's Bazaar | 27 | 20th September 2012 04:02 PM |
| discrete opamp help | blackpowderaudio | Parts | 0 | 16th December 2009 03:46 PM |
| THAT transistor headphone amp (250ma discrete opamp) design sanity check. | Russ White | Headphone Systems | 19 | 13th December 2007 12:52 PM |
| Page generated in 0.12448 seconds (100.00% PHP - 0% MySQL) with 10 queries |
