Go Back   Home > Forums > Source & Line > Analog Line Level
Old 4th December 2012, 03:28 AM   #2311
bcarso is offline bcarso  United States
Originally Posted by scott wurcer View Post
My bad, I set up my first experiment with 2SK170's and left out the cascodes for simplicity. The high Cgs caused the oscillations, back on track now. The input stage looks to match simulation for voltage to current transfer very well. Now to put it all together.
Seems to be the season. I strung together a mostly-air-circuit to do a quick test of a vacuum tube stage and used a base-current-recycling thing along the lines of Aldridge, with moderately slow bipolars (2SA1015, 2SA1249, running at about 15mA). I tested it with a resistive load to begin with and found that it was rather intolerant of capacitive/transmission-line loading. After some help from base resistors I wound up with about 820 ohms in series with the output collector to make it quit convincingly. It was taking off at about 65MHz.
With a much tighter layout it probably wouldn't require as much series R.
Old 4th December 2012, 03:04 PM   #2312
Send a message via Yahoo to linuxguru
Just completed the layout of a folded Kaneda-style discrete opamp with 7 actives, all currently-available commodity SMDs. Here's the link to the schematic and layout:
kaneda preamp
It's about 0.5" x 0.6". Some more space could be saved by using a dual JFET like the 2sk2145, but the singles (2sk209) are easier to source in BL- grade.
Note that it differs from the stock Kaneda - this one is folded, and has rudimentary output stage bias current stabilisation.
Old 5th December 2012, 01:40 AM   #2313
scott wurcer's Avatar
This looks very nice, have you tried it in a few of the standard applications to see where it might shine or not? I/V, line amp, pre-amp, input to PA, etc.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 5th December 2012, 03:29 AM   #2314
qusp is online now qusp  Australia
is choosing a less facetious title...
qusp's Avatar
Scott, just wondering how you think the SW-OPA might go as part of a discrete DSD FIR filter?
seems that given the BF862 are RF jfets and DSD128/256 is effectively almost RF range before the filter, it might be a good match?
Old 5th December 2012, 05:15 PM   #2315
...have you tried it in a few of the standard applications to see where it might shine or not? I/V, line amp, pre-amp, input to PA, etc.
I just gave the dual, through-hole version for PCB fabrication today - probably a month for bare PCBs and a week or two after that for assembly and test. I'm hoping it will do OK in line stages in CDPs, DACs, soundcards, etc. - anything with a high-Z load. It could in principle drive low-Z headphones with a heftier output pair and higher output stage bias, though it wasn't designed for that.
Meanwhile, I've upgraded the SMD version to use Rohm IMX2/T2A duals in SC74 packages, which have higher (300 mW) Pd. I'll probably send it out for fabrication only after the through-hole version comes back and passes sanity checks.
Old 6th December 2012, 01:23 AM   #2316
In fact this looks to be a little over the top in BW and slew rate. I need to build a tighter prototype since this one seems a little to hot. I just got a little too sloppy on the breadboard. Everything looks great but I can still coax a little fur on the output under some conditions. The basic topology seems to be doing everything intended. I will be piggy-backing some real PC boards over the holiday break on some work projects.
Old 6th December 2012, 01:25 AM   #2317
Look forward to your results, I'm not prejudiced in any direction.
Old 6th December 2012, 04:37 AM   #2318
PHEONIX is offline PHEONIX  Australia
Hello Scott,
Have you measured THD yet at say @6Khz.
Arthur
Old 6th December 2012, 08:46 AM   #2319
Originally Posted by bear View Post
Afaik, the 990 used this for the front end:
http://www.ti.com/lit/ds/symlink/lm394.pdf
_-_-bear
Also, why is this going to be anything worthwhile (wrt the above specs for example) since there are a slew of ultra super low distortion monolithic IC opamps now available??
Agreed. I think I'd be more inclined to find something old and contemporary that's in need of some tlc unless some custom deck came up.
Old 6th December 2012, 02:42 PM   #2320
Originally Posted by PHEONIX View Post
Hello Scott,
Arthur
Briefly (with properly applied fingers ) at 10kHz, G = 20dB, 500 Ohm load, and 20V p-p the distortion went into the noise. There also does not appear to be any pathological behavior, foldover, supply sticking, etc.
Remember this started out for me with the intent of using 140V devices and making a PA front end. The available IC PA front ends are not that great.
And this thread has dragged out a great variety of good discrete device options for all projects.
Discrete OPAMP audio-gd Vendor's Bazaar 27 20th September 2012 04:02 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
