Discrete Opamp Open Design - Page 226 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 28th November 2012, 06:26 PM   #2251
PMA is offline PMA  Europe
PMA's Avatar
I have documented the problem in another thread (250MHz oscillations, Agilent spectrum analyzer measurement). Output CFP of DB is prone to UHF oscillations triggered by RFI impulse sent to the output.
Pavel Macura
http://pmacura.cz/audiopage.html
Old 28th November 2012, 06:39 PM   #2252
stormsonic's Avatar
Originally Posted by kgrlee
Got a link homemodder? I'm exhausted from looking through 50 pgs of the Headphone Amp thread.
Do you know if the small pic on the Linear Audio website is the full circuit?
Apologies to those who would have me buy the book. I am counting my pennies.
Go back to August 30th, post #522
Old 28th November 2012, 06:40 PM   #2253
Got a link?
Old 28th November 2012, 06:48 PM   #2254
PMA's Avatar
Somewhere in last days BT thread posts.
Pavel Macura
Old 28th November 2012, 07:14 PM   #2255
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default compl push-pull topolgy as line stage -
I would be happy to discuss the compl- push-pull and the output stage and rfi etc over in the Marsh headphone amp section.... the guts and gore departmment. -RNM
Old 29th November 2012, 12:04 AM   #2256
Pavel, I could only find this
http://www.diyaudio.com/forums/analog-line-level/146693-john-curls-blowtorch-preamplifier-part-ii-2996.html I can't believe I've just looked through more than 350 posts to find it.
But Marshy's headphone amp, neither the pic at http://www.linearaudio.net/index.php?option=com_content&view=article&id=161:a-headphone-bufferamp-and-auto-eq-for-headphones&catid=44:volume-3&Itemid=108
OR
#522 on this thread
are standard 'Diamond Buffer".
So are the Agilent plots of some other evil Golden Pinnae device?
__________
As Mr. Marsh is at pains to point out, he is not putting forward this design to compete with SW-OPA. But for it's intended purpose, and also for a simple buffer or amp, it's elegantly effective if you can select devices and don't mind running 50ma Iq.
I for one am impressed and jealous cos he gets his performance with half the active devices that I need.
Old 29th November 2012, 12:41 AM   #2257
scott wurcer's Avatar
Well on firing up my input stage there was some 100MHz fuzz, so a little work remains. In general it all looks ready, the breadboard is a "little" sketchy I admit.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 29th November 2012, 01:39 AM   #2258
Joachim Gerhard's Avatar
cool
Old 29th November 2012, 05:54 AM   #2259
Send a message via Yahoo to linuxguru
Originally Posted by RNMarsh View Post
Output 'buffer' circuits vary in their isolation ability to minimize the affects.
But it clearly can affect performance .... such as, power amp and loudspeaker reflecting back any nonelinear Z.
...which topology in the output stage has the greatest isolation from output to Av stage...
Though developed as a power chipamp, the Mauro Penasa MyRef uses a nested Howland Current Pump within a global voltage-series feedback loop to address precisely this issue - the effect of a nonlinear load-Z on audible sonics.
There are huge active threads in the chipamps forum on the MyRef and its derivatives. I've built several, and can attest to its outstanding sonics.
Old 29th November 2012, 06:21 AM   #2260
Originally Posted by kgrlee View Post
unlike certain pseudo Messiah's that shall remain nameless ...
Lol - bad-hair day?
BTW, I've preferred simplicity from the beginning of this thread, which is why I picked up on the Kaneda initially, and later played around with the single-ended versions of SWOPA, with various output stages.
IMHO, all have various pros and cons, but if I had to build yet another line-level discrete-opamp to actually listen to music, I'd probably go with a Kaneda/Constellation derivative, despite the fact that it's not an ultra-low THD contender. Why? Because it's simple and only requires a few parts to be matched, and by most accounts, has clean wide-open soundstage and resolution.
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
