| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#2241 | |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Amazon.com: The Mythical Man-Month: Essays on Software Engineering, Anniversary Edition (2nd Edition) (0785342835953): Frederick P. Brooks Jr.: Books
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#2242 |
Mr. Marsh, finally figured out the thread is Marsh Headphone Amp Linear Audio
May I commend you on keeping this modest (?? ) 50 page thread in good order and contributing loadsa good stuff on PCB layout & PSUs too. I very much like your 'modest base requirements' in #279.If I may be so bold .. Is the full circuit this one? Amp & Auto EQ for Headphones It's not clear if this little pic on the Linear Audio page is just the output buffer or the full circuit. I can't see any provision for 12dB gain. It is indeed examplary in its simplicity & effectiveness. ![]() I believe my own modest effort with FET990 may meet your requirements list but at a cost of nearly double the active devices. In return, all I can offer is a reduced Iq of 3mA for the same performance and a less stringent need for matching devices.I'm sorely tempted to treat myself to a beach bum's X'mas present as I see Guru Wurcers 'Supa Dupa Mike Preamps pt 2' is in the same issue of Linear Audio ... and I wanna know wat dis Auto EQ for headphones is too. |
#2243 |
That DB headphone circuit might be a good candidate for potential VHF oscillator
Pavel Macura http://www.linkedin.com/pub/pavel-macura/4/783/637 http://web.telecom.cz/macura/audiopage.html |
#2244 |
I think it's called spectral growth distortion.
#2245 |
expert in tautology
There will be a knife sharpening seminar offered in the lobby... for those who are interested. Tea, coffee and band-aids to follow...
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#2246 |
#2247 | |
#2248 | ||
If you are referring to Marshy's circuit, that's easy enough to solve without affect the performance. 2 resistor values. Quote:
Do you know if the small pic on the Linear Audio website is the full circuit? Apologies to those who would have me buy the book. I am counting my pennies. Last edited by kgrlee; 28th November 2012 at 05:40 PM. |
#2249 |
#2250 | |
Any circuit with Complementary Feedback / Sziklai Pair followers may oscillate if designed badly but the cure is usually simple. In this case, IF there is a problem, the solution is to change 2 resistor values. In a VERY BAD case, you may have to add 2 resistors. There are millions of amps with CFB pair O/Ps which aren't VHF oscillators. I'll concede there are thousands, mainly Golden Pinnae, which do oscillate at VHF from time to time. Last edited by kgrlee; 28th November 2012 at 06:35 PM. |
| Discrete OPAMP | audio-gd | Vendor's Bazaar | 27 | 20th September 2012 04:02 PM |
| discrete opamp help | blackpowderaudio | Parts | 0 | 16th December 2009 03:46 PM |
| THAT transistor headphone amp (250ma discrete opamp) design sanity check. | Russ White | Headphone Systems | 19 | 13th December 2007 12:52 PM |
