| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#2221 | |
Since the VAS output is a rather high impedance point, a voltage follower (emitter/source follower and CCS) could be added, and the feedback taken from that. For those on a "low transistor count budget" this could blow it, but as any engineer knows you can't have everything... |
#2222 |
I proposed long time ago in this thread to have nested feedbacks. And feed-froward by a resistor from input to output of the output follower, balancing such a way power amplification between stages.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#2223 |
I'm afraid you will never find very good complimentarity with JFET's anywhere. They are majority carrier devices one holes one electrons, the mobility difference will always cause something to be amiss. At the very least my observation is that the output characteristics on the P's are always softer, also PFET's do not have impact ionization a direct result of the mobility difference.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#2224 |
Location: Cubicle Sweet Cubicle, Springfield, Missouri, USA
Scott: If p jefts exhibit this non-complementarity, I might be displaying my ignorance but what about an all n jfet output stage (totem pole)? But that would require a balanced push push input signal to the output stage? Thanks Ray
" Where's the KABOOM? There is supposed to be an earth shattering KABOOM." MM |
#2225 |
Correction: Push-pull.
#2226 | |
JC already showed balanced input to the output stage. It looks smooth on the paper, but is bumpy as usual in the reality. What we discussed here, many pages, how to find more optimal design. However, before doing that we did not stop to decide about optimization criteria, so everyone have own in mind.
#2227 | |
I think Scott & I share very clear common criteria; eg low THD, sensible stability adjustment for different loads & gains. no funnies on overload or startup, no Unobtainium, robust to component variations so flexible with voltages, devices etc, optimised for audio rather than RF, good sound. We might also admit to some 'show off' criteria like zillon V/us slew so we outperform Golden Pinnae stuff on the important Hirata & Quan tests. ![]() I'd like to do as well as SW-OPA on the above with less current, less devices & less real estate. ![]() You'll excuse me for not adopting 'new' topologies' unless they show improvements on these criteria over tried & tested. |
#2228 |
is choosing a less facetious title...
i'd also love to see a circlotron type OPA with BF862, that would be 'so fun'
but first this show should run to its conclusion |
#2229 |
#2230 |
No, I'm not advocating throwing the baby out with the bath water. I'll build it the way Scott designs it according to his reccomendations. Ray
| Discrete OPAMP | audio-gd | Vendor's Bazaar | 27 | 20th September 2012 04:02 PM |
| discrete opamp help | blackpowderaudio | Parts | 0 | 16th December 2009 03:46 PM |
| THAT transistor headphone amp (250ma discrete opamp) design sanity check. | Russ White | Headphone Systems | 19 | 13th December 2007 12:52 PM |
