Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th November 2012, 12:04 PM   #2071
lineup is online now lineup  Sweden
lineup's Avatar
Originally Posted by kf_tam View Post
Hi Lineup,
Mr. Wurcer's latest is at #1568, with a slight mod to prevent latch up at #1776. The circuit discription is at #1675. In case you are wondering for a fully complementary frontend, that frontend is at #454, (though the symbols for P channel JFETs were wrong.)
Besides, he also published a FET input version of the JE990 discrete OPAMP at #1510
Thanks kf_tam,
your post is a blessing. Well done.
Now, I will go have a look
Edward Tam
Thanks kf_tam,
lineup
Old 13th November 2012, 12:07 PM   #2072
lineup's Avatar
THis was found in Post #1568
lineup
Old 13th November 2012, 02:36 PM   #2073
kf_tam is offline kf_tam  Hong Kong
Originally Posted by lineup View Post
Thanks kf_tam,
Hi Lineup,
Thanks. I have been waiting to see what you will add the party
Actually, I missed some preliminary sim results from Mr. Wucer but couldn't edit the post.
So here they are: N-ch JFET without cascode#1380 & effect of cascode on PSRR #1542,
N-ch JFET with Rush cascode #1387,
full complementary JFET #1397
The N-ch JFET version was selected, and cascode was added formally #1558, then additional compensation added #1568, JCX's idea of compensation was tested #1725.
Currently Mr. Wucer is testing the output section (diamond buffer) in real life #22032 (as oppose to stimulation only ) possibly out of 2N4401/4403.
BTW, a LTSPICE pack #1577 is also available for anyone to try.
Edward Tam
Old 13th November 2012, 03:08 PM   #2074
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
its Wurcer, not Wucer =) and I think he prefers Guru rather than Mr.
Old 13th November 2012, 03:13 PM   #2075
scott wurcer's Avatar
In the above Q3, 4, 8, and 7 can be ordinary 1N914/1N4148. I think your list of posts included the single 1N914 diode needed to catch a power supply sequencing issue (with it there is no need to worry at all). Depending on particular application not all the compensation components are needed and an output Zobel network should be considered for difficult loads.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 13th November 2012, 03:16 PM   #2076
Actually I prefer to drop the Guru . The name was originally German with an umlaut and a z. Such things were frowned upon by immigration.
Old 13th November 2012, 05:19 PM   #2077
Sorry for this!
Being a former scientist, I prefer to remain completely neutral when reporting the development history
Old 13th November 2012, 07:03 PM   #2078
lineup's Avatar
Hi Lineup,
Edward Tam
What I can add is not very advanced, Edward.
But I have ideas ..... thats a start!
I have one solution regarding OPamp.
It is the link between the input differential and the VAS.
Warning!
I have not seen anyone use this approach before.
Not even John Curl.
This solution can we see simplified in figure #1.
And see it in a working OPamp in figure #2.
There are both benefits and drawbacks.
The benefit it elegantly takes the gain of input stage
and combine it in second VAS into one point.
The drawback is it takes some volts out of Vas stage.
But I like the idea very much.
Let's call it Lineup's JFETspecial.
lineup
Old 13th November 2012, 08:43 PM   #2079
Chris Hornbeck's Avatar
See post #1884. One big issue with the series differential is the matching of devices and/or selection of the common source resistor. But a lot of potential for homebrew.
Thanks,
Chris
Old 13th November 2012, 09:24 PM   #2080
aparatusonitus's Avatar
I have
Discrete Opamp Open Design
And I have another one for you
Non é mai abbastanza...
Discrete OPAMP audio-gd Vendor's Bazaar 27 20th September 2012 04:02 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2013 diyAudio
