Go Back   Home > Forums > Source & Line > Analog Line Level
Old 9th November 2012, 07:13 PM   #2041
scott wurcer's Avatar
Originally Posted by jneutron View Post
Why? Nothing to wear?
jn
Probabley makes me only three degrees from Jimmy Hoffa.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 9th November 2012, 07:55 PM   #2042
lineup is offline lineup  Sweden
lineup's Avatar
What is the latest of this OP Amp by Scott Wurcer. I find it hard to see the final word and a schematic.
If I understand Scott Wurcer he is playing at a league of his own. And this tend to make Op Amp not very basic or simple. But neverless it must be good. Because the man has been doing this to earn his daily bread.
Inform me please of a schematic showing the complete Op Amp so far.
Thank you
lineup
Old 9th November 2012, 08:13 PM   #2043
Hi lineup, I posted a .pdf a couple of weeks ago with my current schematic and description of operation. I forgot the post number.
To me it's not that complicated and I think there are benefits to having the comp cap not referenced to either supply.
Another contender is a FET based JE990 with modern components, this makes sense since many of the ones out there are based on that and it would be nice to put a complete tested version out into the creative commons.
Old 9th November 2012, 08:43 PM   #2044
bcarso is offline bcarso  United States
I agree with both of the above. Quite a reasonable complement of parts for the purpose and the performance.
Old 10th November 2012, 06:05 PM   #2045
I suspect Guru Wurcer will Muntz loadsa stuff once he gets his hands dirty with the input stage of SW-OPA.
If I may make a teensy contribution .. You only need a single diode D1 on the i/p to avoid 'output reversal' on severe overload.
I'm using Cordell's 2n4401/3 models cos they give the worst results both for SW-OPA and my hacked FET990. Also, the real things will give 3.162Vp into 15R without bursting into flames .. at least for a short while
This newbie is really impressed with LTspice on this project. Only suspicious of the i/p stage. Even with fas42's improved BF862, there's stuff I don't believe but I have relatively little experience with FET i/p stages. Maybe try some much simpler circuits with the same i/p stage.
I also don't believe the Vbe on fas42, Cordell, Wurcer & Staccatiss' c2240/a970, BC546/556, n4401/3 BJT models compared to 1n4148/1n914
I'd like to replace a diode connected BJT with 1n4148 in my current mirror. If my (and Scott's) experience is kosher, this shouldn't be a problem as 1n4148 will just show a little more series R. But the models show more volts on the diode connected BJTs. Extra leakage & noise dun matter here.
Old 10th November 2012, 07:52 PM   #2046
kf_tam is offline kf_tam  Hong Kong
Thank you
Hi Lineup,
Mr. Wurcer's latest is at #1568, with a slight mod to prevent latch up at #1776. The circuit discription is at #1675. In case you are wondering for a fully complementary frontend, that frontend is at #454, (though the symbols for P channel JFETs were wrong.)
Besides, he also published a FET input version of the JE990 discrete OPAMP at #1510
Edward Tam
Old 10th November 2012, 08:45 PM   #2047
Originally Posted by kf_tam View Post
.. with a slight mod to prevent latch up at #1776.
Du.uuh! Didn't see that. Guru Wurcer's mod does everything my pathetic contribution does .. & more
Gonna delete my post.
DAMN! Can't delete old posts! Forever shamed!
Old 11th November 2012, 12:53 AM   #2048
Hi Lineup,
Edward Tam
Thanks for keeping track, this weekend is a little busy but I hope to try the basic input stage by next weekend.
Old 11th November 2012, 01:34 AM   #2049
No worries mate!
Old 11th November 2012, 10:43 AM   #2050
post2045
R6 = 1m?
R18 = 1e6?
Discrete OPAMP audio-gd Vendor's Bazaar 27 20th September 2012 04:02 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
