| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#181 | |
Total bill was supposed to be some 12k$ for few 1000 chips. Backed out at the last instant because, no matter how good it would be, it would still be shot down if someone would thoughtlessly use the word 'IC' somewhere ![]() "I'm following this thread with interest". jan
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#182 | |
jn |
#183 |
#184 |
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#185 |
I'm not so sure, but I could be convinced with a simulation that showed lots and lots of 2'nd harmonic with matched devices.
#186 | |
-RNM Last edited by RNMarsh; 24th August 2012 at 05:33 PM. |
#187 |
John, no need for simulation. Use your common sense. It is trivial. I can understand if such solution was proposed as basic block for some digital device, but not for analog amp, especially when we speak about high end.
#188 | |
BTW that other circuit is free of seconds either.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#189 | |
#190 | |
Yes I forgot to mention the circuit can be easily tuned with loading or degeneration for a large range of gnfb. As first presented it is as Wavebourn notices very much in the op-amp vein, very large Aol and very low frequency breakpoint. You'll have to leave me out of the listening though I tend not to hear any differences until they're gross.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. Last edited by scott wurcer; 24th August 2012 at 05:47 PM. |
| Discrete OPAMP | audio-gd | Vendor's Bazaar | 27 | 20th September 2012 04:02 PM |
| discrete opamp help | blackpowderaudio | Parts | 0 | 16th December 2009 03:46 PM |
| THAT transistor headphone amp (250ma discrete opamp) design sanity check. | Russ White | Headphone Systems | 19 | 13th December 2007 12:52 PM |
