Discrete Opamp Open Design - Page 189 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th October 2012, 03:17 PM   #1881
scott wurcer's Avatar
Originally Posted by fas42 View Post
For people's information, I just tried the model of the BF862 that's being used in LTspice, and it does add a gentle curve, slope decreasing towards zero gate voltage, to the transconductance characteristic; a simple, minimal spec'd set of parameters for a JFET just traces a straight line, otherwise.
Frank
Maybe a picture would help. I suggest gate shorted to source and sweep the drain voltage plotting Id, I don't see the B parameter doing anything and the curves are still fit as before.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 24th October 2012, 05:22 PM   #1882
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
either they set B to zero or to one and then simplified from there.
Old 24th October 2012, 05:29 PM   #1883
RNMarsh's Avatar
Originally Posted by MiiB View Post
jfets as cascode devices has an impedance advantage over bipolars... so while capacitance is lower with bipolar the impedance is also lower, so the current swing over rail resistors add more distortion due to waring drive current. each type has their over benefits in cascoding
IMO -- unless you are going for the record in low thd, the distortion reduction due to cascoding will be minimal with high gnfb design. Better to spend time on PSR and CMR. Which cascode in a diff amp input will do better for those parameters? Thx-RNM
Old 24th October 2012, 06:03 PM   #1884
Chris Hornbeck's Avatar
The "Rush cascode" series differential used in the second stage can help with power supply immunity, and is itself improved with conventional cascoding:
Thanks,
Chris
Old 24th October 2012, 11:21 PM   #1885
fas42 is offline fas42  Australia
Banned
Nicely called, Scott, no cigar ...
Original results:
Altered test rig as suggested, and got:
From the LTspice help:
The JFET model is derived from the FET model of Shichman and Hodges extended to include Gate junction recombination current and impact
ionization. The DC characteristics are defined by the parameters
VTO and BETA, which determine the variation of drain current with
gate voltage; LAMBDA, which determines the output conductance; and
Is, the saturation current of the two gate junctions. Two ohmic
resistances, Rd and Rs, are included. Charge storage is modeled by
nonlinear depletion layer capacitances for both gate junctions;
which vary as the 1/2 power of junction voltage and are defined by
the parameters Cgs, Cgd, and PB. A fitting parameter B has been
added. See A. E. Parker and D. J. Skellern, An Improved FET Model
for Computer Simulators, IEEE Trans CAD, vol. 9, no. 5, pp. 551
553, May 1990
Frank
Old 25th October 2012, 12:04 AM   #1886
bcarso is offline bcarso  United States
diyAudio Member RIP
Original results:
Attachment 308141
Attachment 308142
Attachment 308143
Frank
The second graph is not realistic. The sub-saturation curvature transitions abruptly to a linear function. Despite the promising description in Help, it doesn't seem to realize correct behavior.
So it goes.
Old 25th October 2012, 01:28 AM   #1887
Banned
So it goes.
Exactly ... so, at the moment, "no cigar", not good enough ...
I'll have a bit of a look around, and a play, see what might be possible ...
Frank
Old 25th October 2012, 03:03 AM   #1888
RNMarsh's Avatar
what are the actual formulas used in the sim code? whats does the sim software do with the data? If a math major did the code, it might be a lot different than if a device physics major did it. Is curve fitting used?
Old 25th October 2012, 04:20 AM   #1889
Banned
We may have some good news, people ... the Lambda parameter - channel length modulation - is crucial, and may have been set completely wrong in the published model. Playing with figures pulled out of the air I now get curves that look exactly like they're supposed to for the Ids vs Vds plot, but in the wrong place. So I'll start fiddling with other parameters, and see if I can get it to fully behave ...
Frank
Old 25th October 2012, 07:25 AM   #1890
RNMarsh's Avatar
Lambda - even at level 3 model - is often default set to 0.0
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
