Discrete Opamp Open Design - Page 179 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 17th October 2012, 08:53 PM   #1781
scott wurcer's Avatar
Originally Posted by kgrlee View Post
The simplified Wurcer 990 I post in #1692 has excellent performance. On fas42's more stringent 100x 20kHz 20Vpp 600R test in #1694, its actually better than Guru Wurcer's more complex supa dupa circuit.
2nd -101.7dB 3rd -102.8dB Simplified 990
2nd -89.9dB 3rd -89.3dB Wurcer SupaDupa
ricardo 'wannabe a SPICE guru' lee
Just stick a 1N914 in (an oversite). That circuit is a fine option since it can do the 75 Ohm drive. Samuel Groner bases a few on the JE990-ish circuit but this one does not need inductors.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 18th October 2012, 12:31 AM   #1782
The 0.28nV/rtHz version runs 3mA total with 2 of the Hitachi devices. More current doesn't help which tends to confirm the rbb. The 2 'commercial' versions didn't use more current cos there weren't any MC amps at that time that were quieter with real MC cartridges .. even with my non-optimal noise matching. Description is in README.doc[/edit]
That works. As an historical point Nordholt and Van Vierzen ran a custom IC for the same Ortophon cart in 1980 (rbb = 1.4 Ohm). I have probably the only two left in existance. Your complimentary version is far more satisfying and simple (they used a HUGE coupling cap) even though they might have shaved a few tenths of a nanovolt.
Old 18th October 2012, 02:32 AM   #1783
fas42 is offline fas42  Australia
Banned
Originally Posted by scott wurcer View Post
With default values I found the worst case drift AFTER trimming the offset back to zero was about 20uV/C for both pairs of FET's having a 10% mismatch of Idss (combined in the worst way).
I'm getting somewhat worse figures: with perfect matching of 3 FETs and just one out by 10% on Idss the drift is over 50uV, if only the FETs are subject to temperature change. The rest of the circuit offsets the drift to some degree, with the bipolars I've got. If the single mismatch is 17% (the first one I tried) the drift is 100uV ...
Will be interesting to see what the real devices do ...
Frank
Old 18th October 2012, 05:01 AM   #1784
qusp is offline qusp  Australia
qusp's Avatar
i'm all for the complex version myself, i'll try both, but its always good to have options and I want to offer my encouragement for the development of this fresh circuit.
Old 18th October 2012, 11:36 AM   #1785
Banned
Some good news, hopefully ... I mentioned on another thread about using an NTC thermistor for thermal feedback, so tried this as a simple alternative in the sim: the drift caused by a single mismatched FET in the previous post was compensated for, by including the thermistor in a balance of resistors of a current source and managed fairly easily to restrict drift to only 15mV at x100 gain in the range 27 to 57 degC. This equates to a drift of 5uV/degC ...
Frank
Old 18th October 2012, 02:41 PM   #1786
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default second the motion
I'll second that motion.
Old 18th October 2012, 02:44 PM   #1787
RNMarsh's Avatar
Default Thermistor offsets drift
Frank
Shouldnt we prototype the thing and learn the true story on what it 'really', actually does and then see if such is needed or other way? Especially with conflicting sim results...
git er done.
Old 18th October 2012, 03:12 PM   #1788
grhughes's Avatar
PLEASE let's get beyond SIM! We've talked it to death. How about a parts list with the latest additions for both the SWfetJE990 as well as the new SWOPA? It would be great to have a post with the most recent schematics in one post where we don't have to hunt through 179 pages. Thanks, Ray
" Polarities are seldom aware of their polarness." Prospero
Old 18th October 2012, 03:17 PM   #1789
rsavas is offline rsavas  Canada
Default PCB layout assistance?
Hello folks,
I am following this thread as a learning experience. Gives me a chance to learn some analog design techniques & LTSpice as well.
Since it is such a small PCB, I can offer my assistance to continue doing the PCB layout and provide the fab data when completed. No sense in duplicating a parallel effort, if someone else is doing it as well.
I did not get much feedback, when I posted my first attempt, maybe to early for this to be reviewed, that's okay. If you want me to continue, just let me know? If not, good luck with your design!!
Rick
Old 18th October 2012, 03:49 PM   #1790
Thanks Scott!
I gotta confess I originally took someone else's circuit, threw bits out and changed others to get SOTA performance. Just focussing on what's required for good sound and ignoring all Golden Pinnae considerations.
ricardo "whose head is now too big to get through the door" lee
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright 1999-2017 diyAudio
