Discrete Opamp Open Design - Page 166 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th October 2012, 04:58 PM   #1651
bcarso is offline bcarso  United States
Originally Posted by qusp View Post
matching anything is tedious, no way around that. I wouldnt think it would be that bad, i'll let you know =) no I wouldnt think you would need to keep it there long to stabilize, given the size of the device/die I couldnt see it taking long to get up to temp
The 862s are generally pretty close to zero tempco at Idss, so stabilization is quite fast due to that as well.
Old 13th October 2012, 07:39 PM   #1652
Chris Hornbeck's Avatar
I wonder if anybody's interested in a parallel effort to design a dedicated unity gain follower to complement the general purpose op amp?
Thanks,
Chris
Old 13th October 2012, 07:56 PM   #1653
stormsonic's Avatar
You guys are complicating too much about matching rig for BF862 and other SOT23 devices. 2 crocodile clips will do the job. One clip across G and S and other clip on D. Example is bellow.
Old 13th October 2012, 11:20 PM   #1654
scott wurcer's Avatar
Thanks,
Chris
Sounds great, propose some parameters.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 14th October 2012, 12:15 AM   #1655
EUVL is offline EUVL  Europe
I already have umteen versions of those, some published and some not.
Jung diamond buffer, source follower with or without cascode, .....
Also DIP8 compatible and pin compatible with single or dual opamps on 10x10mm footprint.
You just need to tell me what you want.
Patrick
xen-audio.com
Old 14th October 2012, 12:42 AM   #1656
Thanks,
Chris
I've been working on extensions of the linuxguru buffer approach for a client who may not mind their being shared. However, the exemplary performance comes at a steep cost in quiescent power consumption, so they may be of limited appeal.
Old 14th October 2012, 01:46 AM   #1657
qusp is offline qusp  Australia
qusp's Avatar
looks like more of a pain than pressing it down onto some pads, it would also seem to add unwanted thermal mass. It has the bonus of not having to hold them there though; well if you trust them and the attached cables not to snap little legs off if left to their own ..erm....devices (sorry).
though as bcarso mentioned for this part it has close to zero tempco @ idss, that may not be a big deal, at least for the bf862. think i'll stick to something like Scotts method, i'm sure with some thought some sort of mechanism could be found, but I dont thin I could be bothered at this stage.
Old 14th October 2012, 02:22 AM   #1658
rsavas is offline rsavas  Canada
Default Preliminary Layout & Schematic
Crappy day outside, so I gave it a shot and have a schematic a preliminary parts placement. 0805 passives and top-sided only placement, at this point.Retained original ref des, to make it easy to follow. The schematic DOA-SW01.SchDoc has an error Q17 Emitters are tied to the "Out" net.
Rick
Old 14th October 2012, 10:34 AM   #1659
I do not mind high quiescent power - please post.
/S
Old 14th October 2012, 10:45 AM   #1660
donpetru's Avatar
I have attached below an audio preamplifier that can be the basis for achieving an operational amplifier with discrete components.
From experience, the solution presented below I would say that is the best balance between complexity and performance. Of course, the schedule can be complicated but that does not make sense. And if you are thinking complicated diagram, then choose a better operational in capsule, like OPA2134, LME49710 ...
Good luck to all.
AV400v2 and GX400 audio amplifier projects
PCB Design Services - for prototypes OR serial products, Today Tehnium and Forums
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright 1999-2017 diyAudio
