| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#1611 |
I'll get around to the explanation, promise.
![]() A thought occured to me last night, there are several build to print houses in Taiwan that offer some surprising value. With Stinious' BOM down in the $1 range in even modest volume the need to solder all those tiny packages could be eliminated. Another fine point, the resistors along the rails are in a 2,1,3 ratio so 6 resistors of the same (~125 Ohm) value off of the same reel would eliminate having to only get close on the ratios. I would use either 124 or 127 Ohms. It adds 3 resistors but eliminates 2 values. In any case the 375 Ohm ones are not critical so doing this at the input only adds one resistor.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#1612 |
is choosing a less facetious title...
thats an interesting idea mate, but I actually think its a good opportunity for some of these guys that are seasoned veterans otherwise, but are a bit scared of SMD to get to know the new packages they will have to be dealing with, on a small scale project with not many parts, easy to troubleshoot and not much of a loss if it goes up in smoke. some of course are totally comfortable with it, but some could use a push IMO.
I mean no disrespect here, many are much more accomplished DIYers than I am, just not so comfortable with SMD and these are small, but really not very difficult parts to solder |
#1613 |
more of a worry than soldering is matching the little suckers
#1614 |
Location: Cubicle Sweet Cubicle, Springfield, Missouri, USA
BC846BPN ?? How well matched are these complementary devices? They are obviously on the same substrate. Probably more matched that trying to match them ourselves??? Also the resistors around the diff amp: How well matched should those be: .01, .001?? Also I would like to know which transistors need to be thermally coupled to the output transistors. It seems this has been redrawn to suit each contributor and I'd like to stick to Scott's latest schematic. I know that diff amps and constant current sources and sinks if they are current mirrors need to be matched and thermally coupled to not drift. Obviously this simulation will need to be built and go through a parts substitution phase before it is safe to order parts? Waiting in the wings. Very enthused and interested! Ray
" Where's the KABOOM? There is supposed to be an earth shattering KABOOM." MM |
#1615 | |
They appear to have done an admirable job of matching current gains and base-emitter voltages in the vicinity of 2mA Ic. However, the statement early on in the datasheet, "no mutual interference between the transistors", suggests that they are NOT on the same substrate. |
#1616 | |
#1617 |
Hello Scott,
I feel like I'm asking a stupid question but the input stage of the discrete opamp is a pair of BF862 don't these need to be matched for optimum performance. How do you get matched parts , I suspect matching these smd parts is not so simple and a lot of work. If this aspect has been covered in this thread could somebody point me to it. Arthur |
#1618 | |
But testing and sorting is tedious, no doubt about it. |
#1619 |
The test fixture can be as simple as some wave-solder type pads and a bit of weight on the component, to make the contact (Even tweezers would work).. I know it is a bit delicate, but it is possible without being fancy. SOT23, piece of cake, boy I hate DFN, damn cell phone people :-)
#1620 | |
| Discrete OPAMP | audio-gd | Vendor's Bazaar | 27 | 20th September 2012 04:02 PM |
| discrete opamp help | blackpowderaudio | Parts | 0 | 16th December 2009 03:46 PM |
| THAT transistor headphone amp (250ma discrete opamp) design sanity check. | Russ White | Headphone Systems | 19 | 13th December 2007 12:52 PM |
