Discrete Opamp Open Design - Page 161 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 11th October 2012, 02:03 PM   #1601
EUVL is offline EUVL  Europe
Actually quite good as cascode.
Patrick
xen-audio.com
Old 11th October 2012, 10:25 PM   #1602
scott wurcer's Avatar
I think this thread should get a gold star for lack of acrimony.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 11th October 2012, 11:12 PM   #1603
bcarso is offline bcarso  United States
diyAudio Member RIP
I agree. And statisticians needn't worry, the statistics are staying within long-term averages considering some exchanges over in the blowtorch thread.
Old 12th October 2012, 01:46 AM   #1604
qusp is offline qusp  Australia
qusp's Avatar
indeed, probably this is due in part to the majority wanting to actually see something produced out of this exciting event; instead of degenerating into the usual squabble.
ssshhh geniuses at work
Old 12th October 2012, 02:16 AM   #1605
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Old 12th October 2012, 03:13 AM   #1606
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by EUVL View Post
If you refer to the PMBFJ620, then it has much higher noise and much lower Yfs than the BF862.
Idss is also way too high.
The part number and the specs strongly suggest this is two J310 die moulded into a single package. 6nV noise is quite far removed from the BF862 but fairly respectable for a JFET opamp input stage.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 12th October 2012, 03:13 AM   #1607
hhoyt is offline hhoyt  United States
hhoyt's Avatar
Default Acrimony
Yeah, and as such is becoming quite un-entertaining on that level, in order to re-direct those who are here awaiting such antics: (with all credit to Monty Python):
_________________________________________________
Q: WHAT DO YOU WANT?
M: Well, I was told outside that...
Q: Don't give me that, you snotty-faced heap of parrot droppings!
M: What?
Q: Shut your festering gob, you tit! Your type really makes me puke, you vacuous, coffee-nosed, maloderous, pervert!!!
M: Look, I CAME HERE FOR AN ARGUMENT, I'm not going to just stand...!!
Q: OH, oh I'm sorry, but this is abuse.
M: Oh, I see, well, that explains it.
Q: Ah yes, you want room 12A, Just along the corridor.
M: Oh, Thank you very much. Sorry.
Q: Not at all.
M: Thank You.
(Under his breath) Stupid git!!
Indeed...I have read this on other DIYA threads, couched in slightly different prose...
Howie
Old 12th October 2012, 03:19 AM   #1608
abraxalito's Avatar
Default Riiiiiight...
Acrimony? Acrimony? We used to dreeeeeeam of acrimony!
Old 12th October 2012, 05:24 AM   #1609
Absolutley agree, for being productive and instructive as well.
Old 12th October 2012, 05:29 AM   #1610
Originally Posted by fas42 View Post
Hmmm ... in my sim I have very good agreement on the +ve PSRR figures, but the -ve PSRR is dramatically superior at lower frequencies for stinius.
Cgd of the input devices is one of the major paths for +ve PS noise into the i/ps. That's why the PSRR nulls with a particular source Z cos that's when the Zs presented by the feedback network & the source are equal and the CMRR of the amp ignores it. Cascoding the input helps make this effect innocuous.
Having separate CCS for both input devices re-introduces the problem from the -ve supply .. which then need extra cascodes.
But if we
get rid of J1, Q11, 9 and tie the bases of Q15, 35 to emitter & collector of Q7 respectively
doesn't this eliminate the problem from the -ve rail?
Originally Posted by GuruWurcer
Yes that could be, as long as the dynamic base current is captured it all works, time to Muntz away a little.
EDIT - It does not work out that easily, best left alone for now.
Scott, could you explain a little for us unwashed masses why we can't?
ricardo "wannabe a SPICE guru but failing" lee
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
