Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th August 2012, 01:30 PM   #151
dirkwright's Avatar
Originally Posted by Hentai View Post
The biggest advantage that i see in discrete opamps would be higher power supply voltage capability and thus higher output voltage swing.
Right. There's no need for a folded cascode, for example, since that particular circuit was invented to solve a problem that we don't have.
Don't forget current drive. While there are plenty chip buffers that will drive 30 ohms, I'm not aware of very many opamps that can do that (my awareness is very limited however).
Old 24th August 2012, 01:34 PM   #152
scott wurcer's Avatar
Originally Posted by RNMarsh View Post
Please explain in more detail the rising thd with frequency cause. Thx - RNM
The crossover is an "S" shaped voltage discontinuity across the output stage. Inside the loop the current needed in the compensation capacitance is the derivative of this voltage or a "hump" at zero crossing which gets larger as the dV/dT increases (higher input frequency). The more bias (also degeneration tricks) will reduce the size of the discontinuity in the first place.
Clay is embedded in our subconscious. It has been there for at least 50,000 years.
Old 24th August 2012, 01:37 PM   #153
PMA is offline PMA  Europe
PMA's Avatar
One more.
Old 24th August 2012, 01:39 PM   #154
Originally Posted by hitsware View Post
The H in LH was for hybrid (IIRC)
That is correct.
Old 24th August 2012, 01:43 PM   #155
jneutron's Avatar
Originally Posted by scott wurcer View Post
That is correct.
IIRC, it was an active trimmed 4 chip puppy. Back in the 80's, my boss was trying to duplicate it for use in some mil test equipment, programmable ATE.
j
Old 24th August 2012, 01:48 PM   #156
j
Remember the LH0028 "Design a better inamp and we'll give you a job" campaign?
Old 24th August 2012, 01:53 PM   #157
jneutron's Avatar
No, don't remember that. At the time, I was a lowly captive hybrid design engineer, they never let me out...
j
Old 24th August 2012, 02:48 PM   #158
zinsula is offline zinsula  Switzerland
zinsula's Avatar
Originally Posted by PMA View Post
One more.
Like it. Kinda mix between +input stage of AD844 and diff amp of LT1364
No Wilson mirror though.
If you can't trust your ears, then CLICK HERE
Old 24th August 2012, 03:02 PM   #159
bcarso is offline bcarso  United States
Also remember the constraints of chip area, number of process steps, and yield from a wafer when making ICs. Scott remarked that the 2SK170 is larger than some of ADI's recent video amps!
And then there are a host of components that discrete or hybrid designers are free to use that are not available for integration: big caps, semiconductor devices with very different composition (e.g. GaAsP, SiC, GaN), batteries, transformers. It's not a hard and fast dichotomy as clever IC folks are coming up with ever-more diverse means for mixing things. And discrete constructions have benefits: at one time it was junction isolation or nothing, which led to all sorts of subsidiary issues; dielectric isolation (see the OPA627 in question for example) was a great advance. Another tough one in early days was getting good stable resistors.
Thermal issues cut both ways, as inherent matching of monolithic is a plus for ICs, but thermal feedback must be controlled through careful layout and design.
Brad
Old 24th August 2012, 03:46 PM   #160
PMA's circuit looks like two CFA inputs looking at eachother, it lends itself very well to full differential connection.
For that matter that simplified 844 made with discrete duals could be tuned up nicely for several applications. I think there are cheap SMT dual's in the BXXXX series. That's 8 SOT6's and an output pair and you have access to all nodes so you play with Charles Hansen's ideas.
Discrete OPAMP audio-gd Vendor's Bazaar 27 20th September 2012 04:02 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2013 diyAudio
