Discrete Opamp Open Design - Page 149 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 3rd October 2012, 12:18 PM   #1481
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by fas42 View Post
Thanks for that, dadod. I've already looked at your verson, and there's no real difference between the two, apart from the LED and single diodes, not sure what you mean about the comp cap. Yet you were getting close to a null DC output, didn't make sense.
Anyway, in the end it came down to the JFETs subcircuit being very sensitive to the source resistors, if you change a single 25R to a 26R say, then your version shows the same symptoms as mine ...
Frank
Why would you increase 4% that resistor, try 1%?
Compensation capacitor is C4 in my schematic, instead C2 in yours.
dado
Old 3rd October 2012, 12:41 PM   #1482
fas42 is offline fas42  Australia
Banned
Now I'm really confused about your comp cap, in the opamp.asc I downloaded it's C3 ...
With regard to the resistor, I'm concerned about unstable equilibrium in circuits, when everything looks and works fine if the values are "perfect", but if they vary just a little then the circuit behaves very differently. So, if a DIYer happens to use non-perfect parts, or the active devices are not 100% matched in parameters say, then unwanted, larger scale behaviours can emerge ...
Frank
Old 3rd October 2012, 01:06 PM   #1483
Lazyworm's Avatar
Send a message via ICQ to Lazyworm
I agree with Dado,
1% tolerance on resistors is very common, Ithink it is better to specify precision where it is needed then to develope an opamp for the DIYers that use other parts then the BOM suggest.
Old 3rd October 2012, 01:49 PM   #1484
grhughes's Avatar
Default DIY building pains
Frank
YES, I agree! There should be procedure to allow DIYers to MATCH parts. Dale Vishey RN60D, 1% thru hole resistors are readily avaliable. And I believe jfets and bjt's should be matched at the voltage they are gona work in the circuit and not a 9 volt battery. Also most of the parts in my inventory and are avaiable are THRU HOLE (to92) parts. So please don't come up with SOT parts and require a damn microscope to work with them! Just my two cents! Ray
" Polarities are seldom aware of their polarness." Prospero
Old 3rd October 2012, 01:56 PM   #1485
dadod's Avatar
Frank
Sorry, the part of zip file was Wurcer shunt compensation(C3), look at the figure at the post Discrete Opamp Open Design C4 connected between collectors of the Q8 Q9 and R1 R2.
dado
Old 3rd October 2012, 02:25 PM   #1486
A comment from the sideline to Dadod.
When comparing circuits, it is important to make it fair.
If I interpret your circuit properly you are using Ccomp = 100p in Scott's circuit, while using 22p in your circuit, it is of course true that you can lessen Cc when you take it back to the input stage instead of gnd, but not as much as you do.
Here is a Loopgain comparison and a transient THD comparison, each with gain = 5
Another thing is that you use 1kohm load instead of 600 ohms and very low values in FB network.
Cheers
Stein
Old 3rd October 2012, 02:56 PM   #1487
scott wurcer's Avatar
You guys are moving fast, I would hope some kind of breadboard could be made before anyone spends time or money on parts and boards. The last one worked perfectly according to sim but no need to push our luck.
Less time for this for a few days.
EUVL - Thanks for the cascode devices I missed those (J310 which I frequently use for this is only 25V). Boards would be fine but we need a definitive schematic which will still take a while.
On the load drive, this would require a high current buffer or hefty output devices (another version). I never intended this to do 50 or 30 Ohms by itself.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 3rd October 2012, 03:12 PM   #1488
EUVL is offline EUVL  Europe
Ready when you are.
You still have my email address ?
Patrick
xen-audio.com
Old 3rd October 2012, 03:31 PM   #1489
Originally Posted by EUVL View Post
Ready when you are.
Patrick
Yes
Old 3rd October 2012, 04:04 PM   #1490
dadod's Avatar
Cheers
Stein
My intension was not to compare, just simulate it. First I don't know what are suggested JFETs and BJTs. I've got couple of 2sk389 and 2sj109 and I need good line preamp so I simulated it according to that. Regarding GNFB Scott did not suggested starting values, so I used very low values as it gives better response.
You are right about Cc, half than the shunt value is better(47pF) and still distortion is lower.
I noticed that the opamp distortion is quite sensitive to the source impedance.
Here, this one is with more powerful output transistors, maybe Scott can suggest correct currents for it?
dado
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
