Discrete Opamp Open Design - Page 130 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th September 2012, 07:01 PM   #1291
bcarso is offline bcarso  United States
diyAudio Member RIP
The example of a Q =100 resonance is a bit far-fetched, although perhaps useful to capture the concept. Even with a Q = 10, which is rarely encountered, feeding the output of such a resonator to a matched notch filter and switching on a sine wave at resonance produces a burst that peaks after abut 3ms and is 20dB down from the peak after 13ms.
Another observation: the presence of frequency response variations doesn't have to be due to ringing of a resonator as we tend to think of them. For loudspeaker baffles there is a transition in the radiation pattern with frequency that manifests as a gentle boost with quite low "Q". It is entirely appropriate to compensate for this with a simple bridged-T dip in the electronics.
Last edited by bcarso; 26th September 2012 at 07:05 PM. Reason: "with frequency" added
Old 26th September 2012, 07:16 PM   #1292
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally Posted by SY View Post
No, that's not minimum phase and it's also not single-valued.
We are making progress.
The two necessary conditions for a mechanical or acoustical resonance to be electrically equalizable is that the physical system that resonates should be minimum phase and expressed mathematically by a single-valued function . Is this correct?
For minimum phase, you will ask for linearity and time invariance. Say you have it.
Then causality. You have it too.
Next comes stability. Thank you, that scoops many cases out. But oops! Problem. Is there a maximum Q allowed for the stable ones?
Single-valued function.
My understanding is that a function is a single-valued one when and only when itís graph contains no closed loops. Please correct me if I am wrong.
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 26th September 2012, 07:36 PM   #1293
jneutron's Avatar
You are correct, the Q of 100 was used only for concept capture.
My point was that for a chain of sequential elements from input to output, when the transfer of energy from one element to the next relies upon a resonance to build up the amplitude to a sufficient value that it achieves I/O equilibrium, that kills transient response.
I wasn't actually thinking about baffle or cone decoupling issues (but agree), but more of a reflex or 4th order bandpass kinda thing.
j
Old 26th September 2012, 07:40 PM   #1294
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by scott wurcer View Post
I thought we were talking MM, we have discussed virtual ground input MC before. I think John said it makes things sound like "under water".
Our discussion about spherical stylii and the use of pre-distortion on many LP's was a real eye-opener for me.
OK I thought we were talking abpout MC.... typical load was 100 Ohms. I can see JC comment working for the higher Z MM types which used 47K-ish. One thing all this brings up for ME is why I junked the whole thing relating to phonographs and LP's. Just is a big headache that never really gets cured. Esp the distortion levels and on and on. Lets just do the Line level opamp before I get sick and expel my lunch. :-)
Old 26th September 2012, 07:48 PM   #1295
gpapag's Avatar
Originally Posted by Kindhornman View Post
and wouldn't this same phenomena happen with the cantilever, headshell, tonearm and gymbal mechanism?
Oh man! I had kept these same questions for my 120th post to SY.
Brad
You are close to my asking, especially with your last sentence.
When I frequency sweep for to check the impedance of a circuit or a loudspeaker in a Bode plot, it is difficult to see if some small aberrations are indications of small resonances. I then plot the impedance in a Nyquist diagram (real part of the impedance on the X axis. The imaginary part on the Y axis. There, if there is a resonance, the plot makes a closed circle. The area of the circle is indicative of the energy stored there.
George
Old 26th September 2012, 08:12 PM   #1296
forr is offline forr  France
forr's Avatar
Originally Posted by Wavebourn View Post
I found one more interesting discrete opamp. Looks like an instrumental amp loaded on output transformer. V/I converters drive controlled by current common cathode stages with deep feedback by voltage. However it is power amp, but can be used as line level output stage with smaller tubes. Thanks to transformer output can be balanced, for professional studio usage.
This was published in Electronics World, author Jeff Macaulay, if I remember well.
Old 26th September 2012, 08:29 PM   #1297
gpapag's Avatar
Originally Posted by jneutron View Post
Is 20 khz triangular realistic? I would have expected sine for this derivation. Are the peak G's representing slew max or where the stylus hits the vinyl wall?
jn
I was expecting that objection.
Jneutron, I had to do it in my primitive way for to be able to understand it. I used only elementary geometry
Grooves
Acceleration is on part two that is to be published sooon together with an Excel spreadsheet trimmed for SnMs
Of course, there are readily available equations for calculating velocity and acceleration for sines, but these are for normal people. (this is that Jan has not understood about me and asked for new glasses)
Comparing my triangular peak values with the sinus values gives the nice number 1.41…
George
>Edit: Here is a nice method to actually measure acceleration : http://www.luckydog.demon.co.uk/images/Baxandall.pdf
Old 26th September 2012, 08:55 PM   #1298
jneutron's Avatar
Ah, so you are using the zero crossing straight line portion for the calculation?
The first derivative (velocity) of the triangular wave I was thinking of is a square wave, the second (acceleration) is infinite at the transitions.
I thought you might be calculating based on the stylus mass,contact area, vinyl modulus, and vinyl density at the abrupt transition in direction.
j
Old 26th September 2012, 10:10 PM   #1299
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
My respect to Jeff!
The Devil is not so terrible as his math model is!
Old 26th September 2012, 11:37 PM   #1300
Chris Hornbeck's Avatar
Originally Posted by gpapag View Post
For a tip with an effective mass of 0.27mg (Denon DL-103)following a theoretical groove with an 20KHz triangular 5cm/sec modulation, the resulting peak acceleration is 10,000m/sec^2 (1020G).
The inertial force due to this acceleration btn tip side and wall land would be 0.0027N.
Increasing by 20db the modulation velocity to 50cm/sec, these numbers are multiplied by 10.
In a more common case (1KHz at 5cm/sec) acceleration drops down to 500m/sec^2 (51G) and force is at 0.0000135N
I am sure that calculations based on tip dynamics will give wild peak temperatures but wouldn’t published images prove any thermal induced evidence at the groove lands, if that high temperatures were really occurring?
Wow. Thanks, George. That's enough to get into the right order of magnitude, for sure. From here, I'd need to know whether the vinyl acts like a liquid or not, rate of heat transfer, temperature rise due to pressure, effective contact area, and (I'm sure) a dozen other things. It's just too far over my head, and I'm not sure I'd believe anything on these tiny size scales without a measurement to keep me honest. Here's a few references if anybody's interested:
Turntable Forum • Frictional heating of vinyl revisited
but their arguments are not my own. They're interested in tip temperature and friction and I'm interested in vinyl temperature and pressure.
Anyway, I've failed, and need to retract my claim of 400 F instantaneous temperature, pending a measurement.
Thanks,
Chris
ps: Thanks for the great link. I have some photos made for Stanton Corp back in the 70's, but they're matted and framed, so difficult to scan to share. I really need to do it anyway.
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
