Discrete Opamp Open Design - Page 119 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th September 2012, 11:18 PM   #1181
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally Posted by bear View Post
George,
Your diagram shows explicit filter elements or intrinsic resistances and inductances?
It showed intrinsic resistances and inductances.
A bit of this depends on exactly which, since serial filtering *might* yield vanishingly low noise and hum at the end of the chain.
_-_-bear
This is correct bear. It comprises a cascaded RC or LC low pass filter.
In terms of noise and hum reduction is very good and is an economic solution. In theory and more so in practice though has one drawback: Each succeeding stage's DC, rides on the modulations of the previous. If you probe there with an oscilloscope, you will see low frequency modulation. This, together with the voltage drops at the common return line which are different at each stage, cause the signal input from stage to stage to low frequency wander up and down. Visualize a coupling capacitor, the two ends of which are on different, -unequally moving- DC potentials. This, in severe cases may give rise to low freq. oscillation (motorboating).
All these do not occur with parallel connecting the amplifying stages to the PSU
For clarity, I have attached a new sketch, this time with explicit filter elements.
Circuit B is no good at all. It is not a parallel connection (common return) and it lacks the cascaded low pass filtering of the serial circuit.
Originally Posted by janneman View Post
a good way is to determine the stage with lowest PSRR and put the psu closest to that.
jan
With series connection, the circuit closest to the PSU has to be the one with the higher current demands. The furthest away has to be the least hungry for current.
And, if you're serious, use remote sensing for the regulator at that stage.
jan
Do me a favor. Have a look at my avatar please
Originally Posted by Joachim Gerhard View Post
I know that phono cartridges with -20dB crosstalk can just sound fine. Some bleeding in the other channel may even enhance the perception of spaciousness…I rather prefer that not be a characteristic of the electronics.
Originally Posted by john curl View Post
Good stereo separation in the electronics is VERY IMPORTANT. Don't be fooled by phono cartridges Joachim.
Joachim
This time Mr. Curl is correct
The crosstalk within the cartridge is relative “clean”.
The crosstalk between L/R channels in electronic circuits happens mostly through the common PSU lines and less so through spacial multiple capacitive/inductive couplings. All these produce “dirty” crosstalk signals (undefined amplitude phase/delay relationship).
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 25th September 2012, 12:25 AM   #1182
john curl's Avatar
It's about time that I was 'correct'. '-)
"Condemnation without Examination is Prejudice"
Old 25th September 2012, 12:30 AM   #1183
expert in tautology
bear's Avatar
George,
There is a 4th possibility. That would be the first example, but with the grounds of the third.
Also, if the L used is sufficiently high, and the L/C combination "tuned/scaled" well it seems unlikely that there would be much VLF passing. I suppose that if a prior stage was a big current hog that had wild current draw swings, perhaps. But this is not likely for class A stages certainly, class AB stages that are output stages might be another story. There, if we're talking a situation like this thread's design goals, I'd guess that the way to handle it would be along the lines of what Jan suggested, separate regulator/psu.
Where the "ground" is physically/electrically is another issue. Jneutron might be the one to have something on that.
Hey, kids! Get your all NEW and IMPROVED do-it-yourself Op-Amp design kit today! It's easy, It's fun, It's ON SALE NOW!!
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 25th September 2012, 02:18 AM   #1184
fas42 is offline fas42  Australia
Banned
Didn't quite catch that last bit, bear, ya gotta learn to speak up clearly, you hear ...?
Frank
Old 25th September 2012, 02:24 AM   #1185
expert in tautology
bear's Avatar
...send in your coupons before the offer expires... shhhh....
_-_-bear
Old 25th September 2012, 04:01 AM   #1186
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Blend, is flat over frequency, Xtalk is NOT!
Does it matter? As any frequencies tend towards mono the effect at those freqs is to cancel and loose information. That it may happen more at certain freqs (highs usually) isnt the point.
If you want to focus on phono cartridges for a source.... they tend towards mono at the high freqs. But the same thing happens due to crosstalk for a number of reasons and mechanisms. Thx - -RNM
Old 25th September 2012, 06:41 AM   #1187
RNMarsh's Avatar
In addition to a losing details, when the channel seperation become less, the imaging shifts towards the middle/center.
So to have max accuracy in detail info reproduction and to keep accurate imaging, you need to have much better isolation between channels than was recorded.
-RNM
Old 25th September 2012, 08:23 AM   #1188
bcarso is offline bcarso  United States
diyAudio Member RIP
http://www.ibink.com/tnufire/docs/XTalkCancelation.pdf (misspelling in link is not mine)
Also, more recent work that received a lot of publicity: http://www.princeton.edu/3D3A/Public...CHPaperV4d.pdf
Old 25th September 2012, 08:37 AM   #1189
diyAudio Member RIP
Another item of interest: based on level differences only, apparently the threshold for perceiving "all" of the signal coming from one loudspeaker of a conventional stereo pair, in the absence of time delay differences: 13dB, in the most sensitive spectral region (!). The notion that crosstalk reduction into the highest quoted extremes (like the dual mono pursuit) is audible is not supported by data.
However, if the "crosstalk" is really some bleedthrough of severe distortion associated but not identical to signals on the other channel, which can be observed in poorly designed amplifiers, especially low-cost chip amps, this can be quite audible at lower levels. Whether it's appropriate to call it crosstalk or not is another issue.
Also, it's often stated that standard same-signal crosstalk that gets worse (i.e. larger) at higher frequencies is due to capacitative coupling. Although this can be a mechanism, it doesn't have to be the only one.
Old 25th September 2012, 09:20 AM   #1190
gk7 is offline gk7
I hope I´m not too late to ask a question regarding the schematic
John showed in post #971:
http://www.diyaudio.com/forums/attac...scott-type.jpg
What would the approx. open loop gain be ? Would it be usable as a phono preamp
(withsome sort of buffer added to drive the RIAA network) ?
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
