Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th September 2012, 08:28 PM   #1171
expert in tautology
bear's Avatar
My "blend" control is a push button: Waring, Hamilton Beach, etc...
nvm.
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 24th September 2012, 08:40 PM   #1172
Blend, is flat over frequency, Xtalk is NOT!
Old 24th September 2012, 08:43 PM   #1173
Joachim Gerhard's Avatar
I think that this processors i mentioned inverse the channels and then blend them into the other, some with frequency dependent EQ. The argument is that this cancels the acoustic bleeding of right and left ear getting information from the opposite channels too.
Anyway, as much as i tried this it never satisfied me. One was that i could only hear the effect when my head was clamped like in a vice and the other was the rather poor QUALITY of the sound i got so maybe the processors had mediocre electronics. Also the artificial echo generators i bought at the end of the 70th in full rave got switched off after a while. Even multichannel SACD never satisfied me. I can not really describe the feeling but i got disturbed and that disconnected me from the music. Mono is not for me ether, i am definitely a two channel vinyl guy. Maybe because i was raided that way and it feels familiar.
Old 24th September 2012, 09:05 PM   #1174
wayne is offline wayne  United States
In the hills
Originally Posted by john curl View Post
Good stereo separation in the electronics is VERY IMPORTANT. Don't be fooled by phono cartridges Joachim.
Very true. I scratch my head over this but not long.
Old 24th September 2012, 09:57 PM   #1175
forr is offline forr  France
forr's Avatar
I know that phono cartridges with -20dB crosstalk can just sound fine. Some bleeding in the other channel may even enhance the perception of spaciousness.
What I refer to is :
Francinstien
Of course, crosstalk, if needed, should be introduced in a perfectly controlled manner.
Old 24th September 2012, 10:09 PM   #1176
Well, i did not say that i WANT a cartridge with bad crosstalk. Recently i compared the Lyra Titan i that manages -30dB with the new Altlas that has up to -40dB in a broad range because the windings are not on the same former any more and the Atlas sounded better.
In nearly EVERY way.
Old 24th September 2012, 10:35 PM   #1177
Here is a comparison of measurements. One is the Kleos that has both coils wound on the same square former in 90° and the Atlas that has a cross with 4 arms. 2 coils for each channel.
The improvement in crosstalk is obvious. Still this would be very poor for an amp. Yes, i know, Vinyl has no right to sound as good as it does.
Old 24th September 2012, 10:39 PM   #1178
SY's Avatar
Perhaps the 5dB reduction of the horrific peak (and time domain ringing) at 20kHz might be partially responsible for your perception of a better sound?
If there's a sucker born every minute, where do the rest of them come from?
Old 24th September 2012, 10:44 PM   #1179
This cartridges are voiced with a special STAX headphone with extremely low mass.
Mostly critical choir music. There is a cutting and plating loss in the treble and measured more towards the inner side of the grove there is around 3dB loss in the treble too.
I can only tell you that they do not sound spitty at all and yes, extended overtone spectrum differentiates vinyl from CD also i know that vinyl is not very accurate over 10kHz. It may be the simple PRESSENCE of overtones and not the EXACT amount.
Old 24th September 2012, 10:45 PM   #1180
As far as i can tell the peaking in the Atlas is 2dB less and not 5dB.
Discrete OPAMP audio-gd Vendor's Bazaar 27 20th September 2012 04:02 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2013 diyAudio
