Discrete Opamp Open Design - Page 115 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 21st September 2012, 07:48 PM   #1141
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
herein lies the rub-- we cannot seem to be able to do a multi tone test that simulates real music without running into testing hardware issues.... issues the ear doesnt have.
Old 21st September 2012, 07:50 PM   #1142
RNMarsh's Avatar
Originally Posted by scott wurcer View Post
Seek and ye shall find. Someone has one good solution. Note this is a formula to yield very low crest factor not a solution for the lowest possible. It looks like you can get near to 2 or so at 31.
Great find! How can this be done in hardware/software? DSP?
Would Audio-Precision be interested as they have implimented multi-tone already?
Old 21st September 2012, 08:13 PM   #1143
Joachim Gerhard's Avatar
Praxis from Bill Waslo can do it. You can configure the multi tone generator as you wish.
There is also a new wave generator from Agilent where you can create any waveform in Exel.
Old 21st September 2012, 08:20 PM   #1144
33500 Series Waveform Generator Generating Waveforms from Excel - YouTube
Old 21st September 2012, 08:52 PM   #1145
jan.didden's Avatar
I think Rich Cabot read that at the time
The makewave utility lets you specify the crest factor you want and then adjusts all levels to avoid clipping to the max output level you spec.
Edit: at AP.com download tech note TN-18.exe (self extracting zip).
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
Old 21st September 2012, 10:16 PM   #1146
RNMarsh's Avatar
Well lets discuss which one we can all do that works well and start using it on a regular basis. This thd/harmonic, single tone test isn't all of what we are capable of doing and wont help in determining better opamp designs. JC just called and suggests at least a triple tone IM test... better than 2 tone IM. But, lets slug it out here and start using IT.
Which can we all do that doesnt cost the earth and tells us a lot more towards the real application of the opamp - multi-tone signal processing/amplifying. Thx - Dick
Old 21st September 2012, 10:36 PM   #1147
PMA is offline PMA  Europe
PMA's Avatar
It is always the same non-linearity. Interpretation of results (Cabot, e.g.). One can take a twin-tone and move it through audio band. Both IM and HD products are visible then.
I would rather suggest a kind of test that is not limited to audio frequencies only. Like audio band sine + AM modulated or FM modulated HF/VHF carrier. This to be analyzed by FFT analysis in audio band and let's see what products were created.
Pavel Macura
http://pmacura.cz/audiopage.html
Old 21st September 2012, 11:14 PM   #1148
gpapag is online now gpapag  Greece
gpapag's Avatar
Originally Posted by Joachim Gerhard View Post
Here is how that measurement works :
Originally Posted by PMA View Post
Hi George,
no. Depends on SW used, type of averaging etc
Thank you both for replying
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 21st September 2012, 11:39 PM   #1149
gpapag's Avatar
Ref. meaningful and implementable audio measurements, I humbly suggest chapters 22,23 from Bob Cordell book.
George
Old 23rd September 2012, 06:24 PM   #1150
scott wurcer's Avatar
You can use Excel and SoX to directly create .wav files at any resolution and sample rate supported.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright 1999-2017 diyAudio
